1995 powerstroke tps
Old Mar 24, 2018 | 02:17 PM
akmark68's Avatar
akmark68
is the Standard Motor Products APS 102 the replacement part for my truck? I need the complete assembly. This looks identical to what is in my truck but the sites say it is not compatable for my truck
Old Mar 28, 2018 | 09:48 AM
echo95's Avatar
echo95
The APS 102 is for 99 to 2003 and the APS 101 is for 96 - 97 model years. I don't know why a pedal assy for a 96 won't work in a 95 or 94.5. Could be connectors or mounting differences. I'm assuming you don't have a pedal assy there to look at and cross reference some part numbers. Hopefully someone with a 95 will come along to help you if you haven't already solved this.
Old Mar 28, 2018 | 10:31 AM
madpogue's Avatar
madpogue
One of the connectors is different; I forget whether it's the IV switch or the position sensor. Pedal itself looks quite different, but IIRC, the mount points are pretty similar.
Old Mar 28, 2018 | 01:45 PM
95F350CC's Avatar
95F350CC
I recently purchased the APS 101 for my 95 F350, the frame is shaped different and the mounting points won't fit on the 95. The TPS and IVS are identical to the 95. My truck has a very random stumble when starting to move from a stop so I wanted to try a different TPS to see if it corrects my problem. Swapped the new APS 101 TPS into the truck - so far all is good.
Old Apr 4, 2018 | 07:53 PM
carltonwebb's Avatar
carltonwebb
On my son's truck, i was having issues trying to slow cruise out the driveway. It being a manual, it was neckbreaking at times. My issue was the IVS was closing too early. I was able to adjust the IVS watching AE & tps % and get it resolved. Not sure if that could be your stumble or not.
Old Apr 4, 2018 | 08:55 PM
akmark68's Avatar
akmark68
Thank you all for your replies.
My issue is I have only half pedal. Meaning I go halfway on accelerator and after that no change in engine response. Floor it and trans will downshift.
I suspected tps .
Had truck in the shop for new fan clutch and front rotors and pads.
I had them test the tps and definitely is bad. Napa seems not to have the sensor. No luck finding on eBay. Anyone know who carries the tps sensor?
I would rather not have to buy the whole assembly.
Old Apr 4, 2018 | 10:10 PM
95F350CC's Avatar
95F350CC
AKMark,
I have read that the Dorman 699-200 part will work but it does not seem to be overly reliable. It can be seen at this link:
https://www.dormanproducts.com/p-12228-699-200.aspx
Other threads here have some of the details.
P.S. don't buy what Rock Auto says will work. It won't - wrong electrical connector and it turns backwards.
Old Apr 5, 2018 | 10:35 AM
akmark68's Avatar
akmark68
Originally Posted by 95F350CC
AKMark,
Thanks, I was looking at the Rock Auto assembly. That Dorman unit looks like the Napa 2-19093 tps I tried out. I think that might be for 97 and up?
pk8183
18
Oct 13, 2011 02:34 PM
newportman
Feb 3, 2011 01:15 AM
2 stroke man
Aug 31, 2009 04:53 PM
rirwin
Mar 2, 2005 02:47 PM
rirwin
Feb 28, 2005 04:55 PM
