loss of power when shifting gears
Hi all, I have a question regarding my 2000 F550 7.3 manual trans. I noticed several times while driving it yesterday that the truck seemed to lose power and felt like it would stall when shifting gears. I would press the fuel pedal and the engine light would come on and go out after I released the pedal.(engine sounded like it was stuck in neutral) after a few seconds i would press the pedal again and the engine responded normally and I was able to drive and shift normally, like nothing happened. This happened at different speeds and in different gears over the course of the day. Never experienced this before. I should add, that about 3 weeks ago I ran out of fuel. Found out the gauge doesn't read accurately from the person I bought the truck from back in Sept. don't know if that might have a bearing on the problem. Just wondering if anyone has had this happen and point me in the right direction.
Thanks,
George
Thanks,
George
The service engine light means there are codes stored. You need those codes to fix this.
You can read them by downloading Forscan free at www.forscan.org. Their page shows how to select an adapter to plug into the OBDII port. I bought mine from Amazon from about $30.
midsouth
02-22-2012 05:22 AM
99f1504x4owner
02-10-2007 10:23 PM
the_oil_jockey
11-28-2006 12:37 AM
