Stopping popups, internet explorer errors on windows XP
Old Sep 19, 2003 | 12:05 AM
fordmarshall111's Avatar
fordmarshall111
ok, so i ran spybot, 185 errors! CRAZY! so i fixed all of em and then "immunized" against them. and i have a pop up stopper called POW just incase i need one. thanks for the help guys, it seems like its worked!
Old Sep 19, 2003 | 03:19 AM
Torque1st's Avatar
Torque1st
Posting Legend
You can also help by getting a router for your system. With a hardware router your system can not be seen by the outside network. They also allow you to hook multiple computers to your DSL connection. They run about $40-75 at the computer stores depending on features.
Old Sep 19, 2003 | 10:03 AM
drdave's Avatar
drdave
Torque1st, I decided to buy a router (wireless) after it was suggested to me. The reason, I was told, was it acts as a firewall against spyware. I've had problems with websites that you can never seem to exit from. After finally shutting down my PC to remedy the problem and re-booting, I notice that some of my IE settings have changed (default search, home page, etc.). I assume this came from spyware that runs a script on my PC.
I haven't tried to install the router because I have a question. I sometimes have to use my home PC for work (via software) and was told that the router may block my access unless configured correctly. Is this true and what settings will need to be made?
I still need to add the software to block popups, when I get time.
Old Sep 19, 2003 | 05:10 PM
SCS99F-150's Avatar
SCS99F-150
http://www.panicware.com/product_downloads.html
Go here and look for the free pop up blocker, i use and it does great!
Old Sep 19, 2003 | 08:26 PM
acerockola77's Avatar
acerockola77
The problem lies in the operating system.
Old Sep 19, 2003 | 08:51 PM
WhëëlMå1's Avatar
WhëëlMå1
Youre saying XP is the problem? I have had absolutely no issues with it. I have run 95,98,00,ME, and XP and the latter is by far my favorite.
Rich
Old Sep 20, 2003 | 01:05 PM
RA101524's Avatar
RA101524
Netscape 7.1 also has a good pop-up blocker. I use it mostly when browsing some of the more "adult entertainment orientated" sites. It beeps when blocking a pop-up. Sometimes it beeps so much it almost sounds like a symphony.hair
Old Sep 20, 2003 | 01:23 PM
theologian's Avatar
theologian
Originally posted by SHartman
That's your problem. It has nothing to do with IE. Since you now have a static IP address you can be reached by popuppers by a "FEATURE" of XP that is enabled by default. To end your problem right click the My Computer icon and click manage in the menu that comes up. This will bring up the computer management window. Click on Services and Applications. Click on Services. In the list that comes up in the right hand window, locate and double click on Messenger. In the General tab locate and chage Startup type to Disabled. That should end your problem.
Thank you for this information, I just did it, before any problem occured.
Theo
khadma
Apr 25, 2010 08:50 PM
Holiver31
24
Sep 16, 2009 12:00 PM
tjc transport
Jun 16, 2009 10:08 PM
superspike
25
Nov 9, 2004 10:11 AM
kameronth
Nov 4, 2004 03:56 PM
