Weird electrical issue
Old Mar 17, 2018 | 12:18 PM
Ra6hc's Avatar
Ra6hc
So I get into the truck, hit the start stop button and the truck starts up fine. I notice I have no gauges, hvac, radio, power windows, blinkers or lights on any buttons. Turn truck off and restart, same thing. Truck went into drive and ran/shifted perfect. About a mile down the road all everything turned back on. Wrench symbol appreared and said to check manual. Got it home and shut it off. Turned it back on and everything works perfect, wrench symbol went away. Anyone have anything like his happen?
Old Mar 17, 2018 | 01:20 PM
mwheue's Avatar
mwheue
Some trucks have been having problems with water intrusion in the rear wiring harnesses. They all seem to act a little different when this happens. Not saying this is your issue , but something to look at...
https://www.ford-trucks.com/forums/1...ic-issues.html
Old Mar 17, 2018 | 02:55 PM
Ra6hc's Avatar
Ra6hc
I took the rear plug apart and checked all the terminals and it looks perfect
Old Mar 17, 2018 | 05:01 PM
saskowner's Avatar
saskowner
I wonder if it was something like a computer reboot going on.
Gary
Old Mar 17, 2018 | 07:18 PM
wildcard30's Avatar
wildcard30
I had a weird incident when picking my truck from the dealer after a paint repair. I got in it, with one of the service techs to test drive it for a tire issue, and started it. The display was blank, the automatic climate control was on, a/c on, temperature all the way to full hot. We could not turn down the temperature down, we could turn off the a/c but all other lights and switches work, except sync voice command.
After the test drive, I turned off the truck and then back on. No change on the display. The tech said to let the truck off for a minute then start it. I did and the display started working again.
He took in into a bay, connected it to his laptop, and found no issues.
I’ve seen some wired stuff with my fusion hybrid like this. They usually only happen once, for me anyway. It’s almost like the computer code has to have a glitch before it run normally. For me these are listed as a Could Not Duplicate (CND) malfunction. Hard to troubleshoot unless you are looking at the code when it happens. They appear, to me anyway, to be an incomplete boot cycle.
I program PLCs and can usually isolate these type of issues. But not having access to the base code or having the ability to monitor it while it’s running limits what we can troubleshoot.
Old Mar 17, 2018 | 08:50 PM
nico963's Avatar
nico963
https://youtu.be/47vZGYs8ks0
Watch the first minute of this video.I know it's about a glow plug but just listen to the first minute.It may get you pointed in the right direction.
The link didn't work So you'll have to copy and paste it in your browser.Sorry working off my phone cause my computer is down.
Old Mar 18, 2018 | 06:53 AM
Ra6hc's Avatar
Ra6hc
I had the issue where hvac was cuttting out with my plow on. Dealer performed tsp and reprogrammed everything allready. Hoping it was just a fluke thing
Old Mar 18, 2018 | 08:04 AM
nico963's Avatar
nico963
Ok good,Hopefully it was a one time thing.
Hesson81
Sep 27, 2018 03:17 PM
Kevin2112
Aug 2, 2018 10:29 AM
Matt Lichtfuss
May 22, 2018 03:47 AM
Seven Gables
Aug 7, 2017 11:46 AM
srqdiesel chef
Jul 3, 2009 10:29 AM
