ForScan IPC Help Needed
Old Mar 16, 2018 | 06:45 PM
UpInSm0kE's Avatar
UpInSm0kE
I am swapping my 4" for an 8" Cluster and I am having an issue getting the IPC to write my 4" asbuilt data to the 8" IPC. I saved my asbuilt .abt from the 4" and then swapped the cluster and went to load the .abt and it fails every time at 40% when using the write all soft key. I am getting the following errors on the screen of the 8" (check rear park aid, check 4wd, front camera malfuntion) I do not have rear park aid or a front camera, I have 4wd but floor shifter. I am running 2.3.13 on Forscan. Any help would be appreciated.
Old Mar 25, 2018 | 09:01 AM
EGoodie21's Avatar
EGoodie21
Hi there. I have a 2017 F250 XLT as well. I have tried everything to write to the IPC module, and it never works!!! All of the other modules work. I am looking for help too, as you seem to have the same error.
Old Mar 25, 2018 | 11:38 AM
UpInSm0kE's Avatar
UpInSm0kE
What version are you running? Make sure you are upgraded to 2.3.13 and try completely uninstalling and reinstalling ForScan. Mine magically started working after doing the above and went through without any issues. Good luck mate.
Old Mar 25, 2018 | 10:30 PM
EGoodie21's Avatar
EGoodie21
Thank you!! I will try this!
Old Mar 26, 2018 | 05:21 AM
whirledpeaz's Avatar
whirledpeaz
I have had write errors on previous ford vehicles when I was using a cheap chinese elm 327 clone. What obdII adapter are you guys using?
Old Mar 26, 2018 | 10:24 AM
UpInSm0kE's Avatar
UpInSm0kE
I am using this one (listed on the ForScan Spreadsheet thread).
Amazon Amazon
Old Mar 26, 2018 | 10:35 AM
EGoodie21's Avatar
EGoodie21
I have the same one as you listed above! I wanted the USB because my laptop sucks, and i am not sure it has bluetooth.
I noticed I had an error when my stereo wouldnt' display the volume anymore when adjusted, and the bass/treble/mid control was at the max. Turns out the code to remove sirius from the screen was really messing things up. Luckily I saved a backup,
and reset the APIM module to the original. Then I went in 1 by 1 and modified the codes. Found that "Remove Sirius" code to be the culprit.
I had not tried the IPC codes again, because they hadn't worked before, which was disappointing. I may send the device back to amazon if I need the $79.95 bluetooth model to get some other functions.
Thanks!
Old Mar 27, 2018 | 05:19 AM
whirledpeaz
That is essentially what I had when I had problems. ( i had added a toggle switch to mine though ) I switched to the Obdlink mx bluetooth and had no more problems.
Old Mar 27, 2018 | 11:31 AM
EGoodie21's Avatar
EGoodie21
Well this sucks, looks like I will try and return the one i have, and get that OBDlink MX.. haha. I guess I should have gone that route in the beginning!
Old Mar 27, 2018 | 11:44 AM
davidpacificnw's Avatar
davidpacificnw
Newbie here with my F350 Lariat on it's way. Question? What the heck is "swapping my 4" for an 8" cluster". Man, I have so much to learn b4 my new rig arrives. First truck and first diesel. Been around cars all my life, turned a wrench since I was a kid when I was poor and had no money to pay anyone. Now, I like to do my own work for relaxation. Funny how things change!
Old Mar 27, 2018 | 11:57 AM
whirledpeaz
See this thread
azdragger
Jun 14, 2018 02:32 PM
Authenticraft
Dec 7, 2010 11:37 PM
30287f250
1997 - 2003 F150
Jan 18, 2010 08:57 PM
cjbronco
1978 - 1996 Big Bronco
Dec 6, 2004 01:10 PM
Bewbs
1997 - 2003 F150
Sep 15, 2004 05:55 PM
