compression test procedure?
Old Mar 16, 2018 | 05:50 PM
cjben's Avatar
cjben
2004 4.6 Diagnosing misfire codes between 2 cylinders. What is the proper procedure to shut off fuel and spark? I have never done it on a fuel injected engine before.
Old Mar 16, 2018 | 07:49 PM
steve(ill)'s Avatar
steve(ill)
pull the fuse for the fuel pump or trip the inertia switch....... take out all the spark plugs and COPS and set to the side. Hold throttle open when cranking for 5 seconds to measure each cylinder.
Old Mar 16, 2018 | 11:21 PM
cjben's Avatar
cjben
Is this engine one of the engines that had problems braking spark plugs in the heads? are there any special precautions I need to take for them to come out easier?
Old Mar 17, 2018 | 08:32 AM
steve(ill)'s Avatar
steve(ill)
no, spark plug breakage was in the 5.4 motor....... the plugs are buried down in a hole.. best to blow out the hole after COP is off BEFORE you remove the plug. Some like to unscrew 1/4 turn, then shoot some penetrant in the hole and let it set for 10 minutes... I have never had a problem just removing them dry, and cold.
ugh3012
Feb 3, 2017 07:42 AM
dadsutton1
2004 - 2008 F150
Oct 15, 2015 08:53 PM
Wayne64
2009 - 2014 F150
Feb 23, 2010 09:30 PM
Bassgetter
1997 - 2003 F150
13
Jan 11, 2010 03:40 AM
BigDawg54
Modular V8 (4.6L, 5.4L)
Jan 19, 2004 09:26 PM
