Sponsored by: Real Truck
Compression check
Old Feb 2, 2017 | 08:57 PM
ugh3012's Avatar
ugh3012
Compression check
I am going to change out all spark plugs and COP. It is misfiring really bad and it has 170k miles. The scanner said 1-6 cylinders are misfiring. I noticed there are at least three different COP. So, I am going to change them all. When I take one spark plug out to do compression check, what do I do about the fuel coming in? I don't want it to hydra lock.
Old Feb 2, 2017 | 09:15 PM
82_F100_300Six's Avatar
82_F100_300Six
All of the plugs need to be out and throttle body wide open to do a compression check.
Old Feb 3, 2017 | 06:30 AM
WE3ZS's Avatar
WE3ZS
You can pull the fuel pump fuse to avoid having fuel being injected while doing the check (with all the plugs out and throttle wide open ).
COPs do not have a life span like plugs, they tend to live very long and single COPs only need to be changed out with new when proven to be failing. Have you moved the COPs from #1 & 6 (the ones identified as missing) around to other cylinders to see if the misses follow those COPs?
New plugs should always also get new boots and springs, old boots will degrade and develop small (almost invisible) cracks the will bleed voltage out causing a miss.
Old Feb 3, 2017 | 07:25 AM
ugh3012's Avatar
ugh3012
It's not 1 and 6. It's 1 - 6, which is 1,2,3,4,5, and 6 that are reported on the scanner.
Old Feb 3, 2017 | 07:42 AM
WE3ZS's Avatar
WE3ZS
If you are showing an entire bank as missing, I would start inspecting the wiring harness to the COPS on that side.
cjben
Mar 17, 2018 08:32 AM
RaulERichardson
27
Nov 4, 2013 12:36 PM
Nightintruder
Oct 5, 2012 04:34 AM
HotWheels301
Dec 31, 2008 05:10 AM
Higgin
1983 - 2012 Ranger & B-Series
Dec 8, 2004 08:34 PM
