Sponsored by: Real Truck
Front wheel bearings
Old Mar 13, 2018 | 07:14 PM
gabbie07's Avatar
gabbie07
I have a 2012 super duty and am hearing front wheel bearings roar. My question is do I need to replace bearings only or the entire hub. I have been told by Ford that you can't replace just the bearings only but I see that the bearings can be bought by themselves. What do you guys recommend, the entire hubs are expensive as you all know. What do you do when bearings go bad? Thanks for your advice.
Old Mar 13, 2018 | 07:48 PM
Just Strokin's Avatar
Just Strokin
I checked local parts store. They show inner and out races along with bearings for my 2015 2wd F350. You should be able to knock out the bearing races and replace them as long as they are tight in the hubs. Compare the cost of both bearings with races and the cost of the hub to see which is cheaper in the long run. The hub may or may not include the rotor.
Old Mar 13, 2018 | 07:53 PM
SnowPlowDriver's Avatar
SnowPlowDriver
2wd or 4wd? If 4wd the complete Hub assembly is about $200
Old Mar 13, 2018 | 11:03 PM
jetjockey99's Avatar
jetjockey99
The individual bearing and races are for a 2WD, not a 4X4, I believe. The 4X4 is a non serviceable hub/bearing assembly.
Old Mar 14, 2018 | 04:43 AM
Just Strokin
as stated above....need more info....2wd or 4wd..
4wd is similar to a front wheel drive car, you have to replace the hub and bearings as a unit.
bhost1
2009 - 2014 F150
Apr 28, 2017 08:38 PM
Tedster9
Dec 16, 2014 03:42 PM
AMG-SM
Jun 13, 2014 07:30 PM
wrdabney
Dec 28, 2009 08:37 PM
leviticus
Jul 3, 2008 03:56 PM
