Sponsored by: Real Truck
Needle bearings
Old Dec 28, 2009 | 02:57 PM
wrdabney's Avatar
wrdabney
Needle bearings
Can someone tell me what to check on front needle bearings to see if they need replacing. If they do do I have to replace the whole shaft or hub or what? I'm thinkin that the needle bearing is my problem but don't know much about it and can't find anything in the chiltons about it. I have an '01 f250 4x4 7.3
Old Dec 28, 2009 | 04:09 PM
ironmine's Avatar
ironmine
They are interference fit into the center of the bearing/wheel hub. When you remove the bearing/wheel hub, you will see the needle bearing .... look for worn/damaged rollers. If it is really dry, you may want to replace the bearing anyway since they are cheap from NAPA. If you don't replace ... clean and repack them well.
If they are really bad ... you may hear them grind, etc when you rotate the tire/wheel assy with the locking/4X4 hub UN-locked. Upon locking the hub, the offending noise will disappear.
Good luck.
Old Dec 28, 2009 | 05:53 PM
wallz's Avatar
wallz
Do you have any problems with the front end? What is the reason to check for replacement?
You can check on guzzles site for a step by step to take the bearing hubs off and relube. Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old Dec 28, 2009 | 06:03 PM
wrdabney's Avatar
wrdabney
I'm getting a bad vibration and grinding in the front left. I just took it apart and the 4wd locking hub is internally torn up pretty bad. I'm guessing this is my problem. I'm about to order a new hub. Any suggestions?
Old Dec 28, 2009 | 08:37 PM
bubbasz1's Avatar
bubbasz1
Everybody has there own purchasing fancies, depends on how fast you need it. I look in Ebay for good brand name deals, if none there start at the auto parts stores.
Rongold
Aug 9, 2011 09:46 PM
trash
Jan 22, 2011 10:36 AM
wrdabney
Jan 2, 2010 05:14 PM
Bowstring
Oct 18, 2007 06:16 PM
t4kne
Jun 22, 2003 12:22 PM
