Steering : What was your solution?
Old Mar 11, 2020 | 08:38 PM
  #31
afonda's Avatar
afonda
Originally Posted by Ridedan2
It may be worth checking your 4x4 u joints. Mine were rusted which caused binding in the steering, the truck would wander as if it had a mind of its own.
yeah.. but they are floating axles...
Old Mar 11, 2020 | 08:51 PM
  #32
Ridedan2's Avatar
Ridedan2
yeah, mine too...
Old Mar 12, 2020 | 06:58 AM
  #33
SkySkiJason's Avatar
SkySkiJason
If the u-joints don’t flex correctly, they will cause the steering to bind.
To check steering components, have a helper turn the wheel back and forth just beyond the play. You’ll use a light and look at each tie rod end and and the pitman arm. There should be no slop at any of these connections.
This is what ive been using for replacement.
https://www.ebay.com/itm/Steering-Ti...UAAOSwyOVdqvf2
glen_melton
Mar 16, 2017 12:42 PM
acw592
Dec 3, 2009 09:16 PM
FordF350Baby
Sep 5, 2009 09:25 PM
kameronth
1978 - 1996 Big Bronco
Sep 11, 2004 07:03 AM
BAD84F150
Sep 10, 2003 12:39 PM
