Sponsored by: Real Truck
Changing The Steering Box
Old Jan 26, 2009 | 04:51 PM
acw592's Avatar
acw592
This is my first diesel, 2000 F250 7.3 Powerstroke crew cab. I love the truck. Going to install a 5" lift very soon with mickey thompson classic 2's and 35" tires. I need to adress a couple of steering issues first. My steering box is very loose and the tie rod end that atatches to the pitman arm also needs changed. Was wondering what the best plan of attack was for changing the box? I see the 4 bolts on the frame and it looks like if I knock the rod end off the pitman arm, then I'll just have to remove the steering shaft from the box. Not sure of the correct term, but it looks like if I removed the air duct that goes from the turbo over the top of the steering box, then hopefully I can get the steering shaft removed from the box. If anyone that has done this could tell me whether Im going about this the right way or not, I would greatly appreciate it! Thanks
Old Jan 26, 2009 | 06:55 PM
Fordfanatic4life's Avatar
Fordfanatic4life
first off are u certain the actual steering box is worn out ???
alot more likely the rest of your steering system has worn parts then the box itself..
check to make sure u dont have play in the actual pitman arm itself.. althou i suppose if it were worn then its likely the splines on teh steering box would be aswell..
if i were u i would make certain the box was bad before commiting to removing it...
Old Jan 26, 2009 | 09:12 PM
ReAX's Avatar
ReAX
I would agree. It takes quite a bit of work to wreck the steering box and the other items should be addressed before diagnosing the gear box. To diagnose the gear box even with new components, I would watch both the input and the pitman arm for movement. Ideally, if the input moves, the pitman arm should. There will be a difference in ratio, but a slight movement of the input should result in a slight movement in the farthest end of the pitman arm.
You should also have an adjustment on top of the gear box. Once you have linkage replaced, you can try to tighten the box up a little. When all else fails, then it's time to pull the frame bolts, pitman arm (they don't usually come with new ones), the rag joint and the hose connections. I usually do the hoses first because they are a pain on old trucks. Once I have them loose and don't have to replace any, then the rag joint and pitman arm. Finally and very carefully unbolt the box from the frame.
They are very heavy, you are usually laying in it's path of falling. If not your head, then your chest.
Old Jan 26, 2009 | 10:33 PM
acw592's Avatar
acw592
Thanks for the reply's. It is for sure the box. Even though I plan to start removing it tomorrow I tightened the ajustment screw on the top some this afternoon, which did tighten it up, but I need to just replace it and get it over with. I hate loose steering. I did check all the front end components, ball joints tie rod ends ect. Looks like I will get by with the steering box and the tie rod end that connects to the pitman arm.
Old Dec 3, 2009 | 02:33 PM
lanidan's Avatar
lanidan
this is the same problem that I am having my 2000 f250 7.3l. I hear a knock in the front left and there is a fair amount of play in the steering. I friend of mine is the service manager at a local dealership and said the steering gear nneds to be replaced. I have been learning as I go on this truck and have not had to deal with this particular part before.
Is this something that can be done in my garage or is it something better left to the pros? My friend wants between $600-$700 to replace it. So I'd rather do it myself if I can. Is there any place I can look for some help? I didn't see anything else when I searched the threads.
Thanks for any and all help
Old Dec 3, 2009 | 03:25 PM
SGnAZ's Avatar
SGnAZ
https://www.ford-trucks.com/forums/9...light=red+head
Old Dec 3, 2009 | 03:28 PM
SGnAZ's Avatar
SGnAZ
https://www.ford-trucks.com/forums/8...installed.html
Old Dec 3, 2009 | 09:16 PM
98SurplusExpy's Avatar
98SurplusExpy
I just replaced the steering gear in my 2006 like a few weeks ago. I got the a reman from A1 Cardone via CarQuest and it is spot on. The steering is now nice 'n tight and leak free (leaking was the reason I changed it).
Mine is a 2006 and I'd say the job wasn't difficult. You WILL need a special pitman arm puller for the fat end of the pitman are. This is not available at your local parts store for rent ... I had to order one from Lisle (Lisle #41970 Ford Pitman Arm Puller). You'll also need a torque wrench with a 350 ft/lb capability. Also, you may need to visit your local Ford dealer and pick up some teflon o-rings and/or rubber o-rings.
The write-up in the forums on the "redhead" gear replacement is also a good reference source for pre-2005 models.
72CC428
Apr 29, 2016 02:11 PM
Road Warrior 95
Jul 5, 2014 09:55 AM
Misky6.0
Feb 18, 2013 09:50 AM
okedokeno
28
Oct 26, 2012 10:45 PM
Brian085
Jul 22, 2012 10:01 AM
