Torque baro reading
Old Mar 12, 2018 | 06:39 PM
milehi_350's Avatar
milehi_350
Torque baro reading
How accurate is this reading? I either have a problem with the reading my PCM puts out or with torques interpretation of that reading. I am In the Denver area so somewhat high altitude. Torque reads anywhere from 11.8-12.2 psi which doesn’t match the current weather report of pressure nor does it translate to a proper altitude reading.
Old Mar 12, 2018 | 07:46 PM
The Brad's Avatar
The Brad
Your baro is reading in PSIA while the weather report is probably in inches of mercury, InHg. At 1900ft elevation I read about 13.8psia usually. The current pressure in Denver is 30.14InHg according to my weather app and I’m assuming that’s a sea level reading which would equate to around 24.7InHg at 5000 ft, which is roughly 12.1psia.
Old Mar 12, 2018 | 07:59 PM
milehi_350's Avatar
milehi_350
Yes. Pressure here is usually around 30.2 inHg which converts to 14.8 psi. That’s not close to what the torque reading is.
Old Mar 12, 2018 | 08:05 PM
The Brad's Avatar
The Brad
I’m pretty sure the weather is giving a sea level reading.
Old Mar 12, 2018 | 08:07 PM
milehi_350's Avatar
milehi_350
Okay. I’m more confused now. It gives Denver atmospheric pressure at sea level??
Old Mar 12, 2018 | 09:08 PM
The Brad's Avatar
The Brad
Either that, or you have one hell of a high pressure system moving through. What do MAP and EPB read? They shoud be the same as baro KOEO.
Old Mar 12, 2018 | 09:12 PM
milehi_350's Avatar
milehi_350
Thanks Brad. I didn’t know that pressure readings are made at sea level then adjusted for altitude.
Old Mar 12, 2018 | 09:14 PM
milehi_350's Avatar
milehi_350
They are all within .3
Old Mar 13, 2018 | 08:17 AM
Tugly's Avatar
Tugly
Bingo... that means all is well.
Rumble phish
2004 - 2008 F150
Jul 18, 2025 11:50 AM
Tugly
223
Aug 18, 2019 07:36 AM
ebbnflow
Dec 11, 2018 02:26 PM
bkuuz1
6.7L Power Stroke Diesel
Mar 21, 2016 11:19 AM
Ford1TonsRock
May 18, 2004 10:40 AM
