9 inch posi?
Old Mar 12, 2018 | 06:25 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by ranger140892
Ahhhhh, yes true. Spline Count! Thanks for correcting me.
Grandpa, if this seems intimidating, don't sweat it. It's not. You can get your gear ratio from the door tag. You can measure the universal joint caps and yoke length.
As for spline count, the only way I know to get that is to pull one axle shaft and count the splines. It's pretty easy but be prepared for the axle bearing to come apart. I would never put an old bearing / seal unit back in there anyway.
IF the rear axle ID tag is present, post the ID number from it. I can look up the axle shafts from that, then let you know the spline count. Tis a lot easier than pulling an axle.
1974/79 with 9 inch: TWO different types of axle bearings. One is the large ball bearing type (also used 1961/73 & 1980/86), the other is a tapered roller bearing/seal combination.
Old Mar 12, 2018 | 10:57 PM
Lukas Nicolay's Avatar
Lukas Nicolay
Somewhere between 77-78 they changed axle bearings
5.0punisher
2015 - 2020 F150
May 30, 2019 03:54 PM
Mowing Man
22
Jun 27, 2014 05:40 PM
6ohman2004
Jan 18, 2014 07:12 AM
goodwrench
Aug 29, 2005 10:37 PM
Ken2600
Feb 17, 2003 12:03 PM
