Sponsored by: Real Truck
Broken bolt
Old Mar 11, 2018 | 03:29 PM
usmarine1979's Avatar
usmarine1979
Broken bolt
Hey guys I really need some help here.
I was removing cylinder #6 fuel injector and the head of the torx bolt stripped out. I tried extractors until the head was gone, so I ended up just grinding the head off to get a left handed drill bit in it. I'm about a quarter of the way through the dog gone injector hold down clamp with left handed bits and no movement from the bolt. The bits are no longer cutting, and are just kind of bouncing in the hole.
I really need some help with how to get this thing out, so if you have any advice I would greatly appreciate it.
Old Mar 11, 2018 | 04:10 PM
None2Slow's Avatar
None2Slow
I pulled a broken exhaust manifold bolt from a 2008 Chrysler Aspen 5.7 head. I started with the smallest bit, then worked my up to the size chart. Eventually the bit got "wedged" in and when I backed the bit out, it brought the bolt with it. My plan was to use an easy out, but didn't need to. I have had this happen on at 3 occasions.
Old Mar 11, 2018 | 04:21 PM
seville009's Avatar
seville009
If what’s left is loose and you just can’t get hold of it, maybe try a strong magnet to suck it out (or even a strong shop vac)
Old Mar 11, 2018 | 05:23 PM
miranda machining's Avatar
miranda machining
If the drill is just sort of bouncing around it may be because the drill was dull and not cutting and so as it was just sort of "rubbing" you tried to compensate by pushing harder which produced enough heat to work harden the bolt.
If you have access to a carbide drill bit I would switch to that til you cut through that hardened portion and you should be able to drill normally again.
Old Mar 11, 2018 | 08:05 PM
Tom's Avatar
Tom
Is this on a 6.0L truck? I can move it down to that forum if it is, you might get some better advice down there.
Can you post a photo?
gabriell12123
Jan 26, 2019 07:27 AM
DirtySCREW
1997 - 2003 F150
Mar 30, 2013 11:03 AM
superduty4x4
32
Apr 1, 2008 08:08 PM
Bostonsound
Feb 26, 2008 06:01 AM
richlars
13
Nov 14, 2005 01:04 PM
