Sponsored by: Real Truck
Big problem! Need help ASAP
Old Jan 17, 2019 | 09:59 AM
gabriell12123's Avatar
gabriell12123
was doing head gasket on my 99 f250 5.4l and I head bolt snapped 2-3 inches in the block. I think the torque wrench I was using was faulty (never clicked/buzzed/flashed/vibrated nothing) or it could have been some faulty bolts ( bought online appeared to be new but where the old design in a old battered box) It snapped rigid so drilling it out hasn’t been working to so well, I’ve tried butting the bolt up the the snapped portion to see if it would back out with no luck. The bolt didn’t bottom out yet. What can I do?
Old Jan 17, 2019 | 01:08 PM
Colorado350's Avatar
Colorado350
This works great I’ve used it many times.
Old Jan 17, 2019 | 01:52 PM
Sir Kayakalot's Avatar
Sir Kayakalot
https://youtu.be/6mZj0J6CNYA
That is the only good option when the bolt is broke off deep down in the hole. Works great just take your time when making the guide bolt as it is critical that the guide hole is perfectly straight
Old Jan 17, 2019 | 06:18 PM
Chuck's First Ford's Avatar
Chuck's First Ford
reverse twist drill bit.... as its drilling, it also is trying to unscrew the broken bolt. the above guide is very helpful..
if the broken bolt is TRULY NOT bottomed... a long skinny flat blade screwdriver.. and try to walk/rotate it out..
if its NOT bottomed, no pressure is on the threads to restrict movement ..
Old Jan 23, 2019 | 08:41 AM
gabriell12123
That seems like the best way but I don’t have the tools to make it, what else can I do? would hate to have to haul it to a machine shop.
Old Jan 23, 2019 | 08:53 AM
redford's Avatar
redford
FTE Leadership Emeritus
You are basically between a rock and a hard spot.
At this point you either need to find the tools needed to extract the bolt, or let a machine shop do it for you.
You might try calling a few of the national chain auto parts stores. They sometimes loan or rent tools out to customers.
Old Jan 23, 2019 | 08:54 AM
wess23's Avatar
wess23
How big of a hurry are you in?, I have the tools to make one if you could tell me the thread size and pay the postage.
Old Jan 23, 2019 | 11:45 AM
gabriell12123
it’s not a daily or even a registered vehicle so not really in a huge rush just would like to get it put back together the thread size I will have to get figured out unless somebody has that answer for me I am willing to pay postage where would you be shipping from?
Old Jan 23, 2019 | 12:45 PM
Sir Kayakalot
Willing to pay postage?! You better buy that man some beer!!
Old Jan 26, 2019 | 07:27 AM
gabriell12123
What’re you drinkin wess?
HelenT
Oct 1, 2018 12:19 PM
tanagerhills
May 11, 2017 09:41 AM
DirtySCREW
1997 - 2003 F150
Mar 30, 2013 11:03 AM
Fordy Four
May 7, 2008 11:07 PM
tweakingit
Sep 29, 2003 07:34 PM
