Fixable?
Old Mar 10, 2018 | 01:24 PM
James Eichert's Avatar
James Eichert
Fixable?
Can I cut this piece out below the windshield and weld a new one in? Can I order just that piece? I’m pretty well set in my mind on doing a cab swap just wanted to get another opinion.
Old Mar 10, 2018 | 01:29 PM
67xr7kat's Avatar
67xr7kat
Cowl ?
Looks like a solid hit, is the frame bent ? Where are you located ?
Nat
Old Mar 10, 2018 | 01:47 PM
James Eichert
I don’t think the frame is bent. I bought this from my buddy who had just finished rebuilding everything mechanical when this happened. Slid off the highway and mowed over some lodgepole. I’m located up in western Montana
Old Mar 10, 2018 | 09:20 PM
speedfreak78's Avatar
speedfreak78
Anything's fixable if you want. If the rest of the cab is solid, fix it. You'll have to cut one off something else to replace it, I don't think it's reproduced. You could probably straighten out what's there and get it pretty close if it's not a show truck.
Old Mar 10, 2018 | 09:47 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
That is a main cab/firewall piece are you ready for some work? Big question is can you locate a parts truck/cab because that piece is NOT reproduced. Sad when that part gets a dent.
Old Mar 10, 2018 | 09:54 PM
77&79F250's Avatar
77&79F250
That piece is connected to ALOT of interior panel pieces. My buddies door hinge areas were rusted bad, so we hacked the replacement panels out of a parts cab...hard work for sure.
Old Mar 10, 2018 | 10:06 PM
Houstonj's Avatar
Houstonj
Anything is fixable with time and the right tools. Just have to make sure if it's worth fixing or just swap the cab.
Old Mar 10, 2018 | 10:17 PM
willowbilly3's Avatar
willowbilly3
I'd say it's a parts truck, or do a cab swap. There is a lot of work to do there and a lot of things that need to align. Possible, yes. Worth it? not to me.
Old Mar 11, 2018 | 09:19 AM
James Eichert
Thanks for the help guys. I talked to a friend last night about a 79 pickup he has that he’s willing to sell. That truck is a 4 speed which I was going to start sourcing parts to swap out the c6 in mine for a np435.
EffieTrucker
Jul 17, 2014 07:17 AM
tiger_698
18
Oct 20, 2010 01:09 PM
bulletsneverlie
Feb 28, 2010 06:23 PM
IndyGTA
20
Nov 27, 2009 08:55 PM
ssj7kids
Jul 24, 2007 08:59 PM
