Sponsored by: Real Truck
Help with spare tire
Old Mar 10, 2018 | 11:06 AM
Dude357's Avatar
Dude357
Question Help with spare tire
I have a 2015 F350 DRW King Ranch that I bought used. While traveling out of town I got a screw in one of the outer rear tires. I called roadside assistance but they were unable to remove the spare because the truck did not come with the key. I went back to the dealer I purchased from and they said they would get one for me. The dealer could not get one of the keys from their master set to work. After talking with their head mechanic I realized that the set of master keys he was using was 10-15 years old. Does anyone know if their is a newer set of master keys or if they changed anything about them. The end on my truck does not appear to be damaged in anyway but seams to be a larger diameter then the key set the dealer has. Any suggestions
thanks
Old Mar 10, 2018 | 11:27 AM
speakerfritz's Avatar
speakerfritz
There are various methods to remove the lock, you can search the forum for all of them.
i used the sears grip tight socket on one truck and a cold water pipe with a cotter pin clipped to the end on another truck.
the only folks who can’t get the tire off are the ones trying to use s key to do do
theives will just pop the locking device.
Old Mar 10, 2018 | 11:31 AM
Colorado350's Avatar
Colorado350
I had the same issue. Crawl under the truck, vise grips, small blocks of wood. If you pull down on the spare you should be able to have limited access to the spare tire hoist. Push a block in there to hold spare out of the way. Pull the plastic sleeve /guide to rear of the truck, this will give you access to the lock. Using a vise grips and PB blaster, wiggle the lock out of the hoist housing. You can also use a bolt extractor I think IIRC 3/4 or 18mm to remove the lock. Once the lock is out throw it away. I use a HF 3/8" socket extension to raise/Lower the spare tire. Hope this helps. s
Old Mar 10, 2018 | 12:17 PM
Just Strokin's Avatar
Just Strokin
If you are wanting to retain the spare tire lock, you can contact Customer Service at McGard. They can possibly help you id the key needed.
Home
Old Mar 10, 2018 | 04:34 PM
SnowPlowDriver's Avatar
SnowPlowDriver
I had the same problem with a 2012
Dealer had a master set of 12 keys but wrong size. A change in sizes occurred somewhere between 2001 and 2011. Use the gripper socket to get the tire down them remove the lock and discard it.
Old Mar 10, 2018 | 09:06 PM
fordman19762003's Avatar
fordman19762003
First thing I did when I bought my '13 was remove the lock and throw it away.
Old Mar 11, 2018 | 08:25 AM
Chuck-B's Avatar
Chuck-B
6.7 Weight Loss
They can’t order you the correct key based on VIN?
Rasm616
Oct 27, 2017 03:15 PM
JustKevin
1997 - 2003 F150
38
Jan 18, 2015 03:33 PM
Liquid10Rider
May 21, 2012 10:37 AM
ascheperle
Apr 18, 2010 12:44 PM
djust
1983 - 2012 Ranger & B-Series
Dec 27, 2006 05:26 PM
