Hpop issues need help
Old Mar 18, 2018 | 02:10 PM
Tideman's Avatar
Tideman
How long did you crank it? Sometimes it takes 10 - 15 20-30 second cranks(with rest in between) to fill everything back up with oil. And use the jumper wire not the key and KEEP those batteries charged or you’ll damage your FICM.
Old Mar 18, 2018 | 10:36 PM
7.3 forever's Avatar
7.3 forever
I definitely cranked on it long enough with giving it brakes in between and a charger on it to keep batteries up. I didn’t think about using wire and not key I do same thing on my 7.3. 6.0s are definitely a new territory for me but I may give it another few cranking sessions. Maybe it takes a little longer with a 6.0 but I honestly feel like it should have started or atleast be building more hpop pressure guage on guage cluster was registering oil pressure
Old Mar 19, 2018 | 07:22 AM
navistarnut's Avatar
navistarnut
Pull the ICP and see if the oil rail is full.
Does the gauge on the dash blip up a little bit?
Is the oil filter reservoir filling up when you crank it?
fuelsmoke1
Jul 5, 2019 07:58 AM
waistline00
Aug 26, 2017 06:24 PM
piken
Mar 3, 2016 01:02 AM
dothedew192
Feb 21, 2016 09:58 AM
tjspates
Sep 21, 2015 03:14 PM
