I do have an update. The dealership and ford have diagnosed the truck with having a failed clutch pack and a bad wiring harness. However they will not be replacing the transmission but installing replacement parts instead . This is unbelievable to me, the transmission has had a major failure and it has contamination in the entire system including the cooler and torque converter. They simply refuse to listen when I tell them this is not an acceptable repair and it is doomed for failure. How do they expect components that have been overheated and contaminated to last? I feel like the dealership is using my truck as a test mule for their own learning experience and I am tired of it!
Believe me, I get the frustration...I'd be more convinced that it was fixed if they did a complete replacement. Especially on such a new truck.
But do you really think every overheated transmission gets thrown in the trash and replaced? A well-trained transmission tech knows how to inspect for damage and will replace components that were affected. It's not uncommon for lots of seemingly unrelated parts to be replaced when they do this, as they have to warrant the repair. If they couldn't confidently affect the repair, and it came back needing another teardown, labor costs would make this far more expensive than replacing the entire thing the first time. It can be fixed correctly, let's just hope your dealer knows what they're doing with a transmission.
At least there is a diagnosis. I think the smart play here to request an extended warranty on the transmission and related electrical components. If Ford and or the dealer balk at this, then i'd be pissed.
Good advice, and would give you confidence as well.
The good news is that he did get one already which should at least give him peace of mind.
Originally Posted by ford390gashog
....I really must say Ford really stepped up on this and offered to put me in a rental truck and gave me an extended powertrain ESP to cover future issues....
Wow!! That is disappointing...and you have the right to be upset. Have they verified that the system is contaminated?? If no or little contamination in the system, then the replacement parts should be good enough. However, the system will need to be flushed, plain and simple.
IMHO...I would insist on seeing the damaged parts. Especially the clutch packs. Document the findings with pictures.
Good luck with getting it resolved and enjoying the truck!!
I saw the parts first hand, burned clutches, over heated steel clutch plates and metal flakes in the fluid. They are still waiting on parts and it's now going past week 3. You can't flush the cooler or torque converter so I see this whole transmission being doomed!
What does a defective wiring harness have to do with burned up clutch packs? Was an open or short in the harness supposedly making it shift wrong and burn up the clutches?
Okay here is the next update. I finally got the truck back after almost a full month at the dealership this time. They replaced lots of parts. However there is a discernible noise while in drive at a stop. Something is rattling, but I am okay with it! Because Ford has really come through on this for me! Ford has agreed to take the truck on a buyback as a lemon and they also covered my rental car for the month 100% also. I will update again with the outcome.
Damn, sounds like you talked to the right people. Maybe they are gonna run further tests on it?
Glad to hear they're taking care of you here. Apparently their "cost cap analysis" proved to be incorrect, it would have been MUCH cheaper for them to just replace the transmission!
I was wondering about that too. Just one day of labor, and suddenly the cost of the transmission seems much less of an issue. I've got to think that someone at that dealership (or somewhere) wanted experience digging in to this transmission, or else someone wanted to see what went wrong in case there was an undetected design flaw.
That said, if Ford wanted to analyze it, it seems it would have been quicker/easier/cheaper to swap the transmission, and send the broken one back to Ford for whatever postmortem they wanted to do with it.
Hey, what year truck we talking about here 2017/2018), I getting ready to pull the trigger on a `18, ordering one -with time running out, I been looking buy since 2017, if there is more chatter out there on this- it might move me to the '19!, I am surprised by the fact Ford decided on a new truck, that is what I would want- not the same parts that caused the problem, I had the 6.0 with no support...so are you all in agreement that this is an isolated incident (bad draw)? I was busy researching the engines and came across this, looks like a new Web search
I'm also glad they are making it right for you. I've been following this thread because I have an 18 with less than 2000 miles that the trans has done some unexpected and not so good things. Like an uncommanded shift from 4th to 1st at 35 mph. And of course the dealer couldn't find anything wrong with it. I've looked at these transmissions and I doubt that any of the problems are the fault of the trans itself. I think it is sensors, wiring or the computer. And that could be why they want the entire truck back instead of changing out the transmission and related parts. I don't know what one of these 10 speeds cost Ford but you can buy them all day long from salvage yards with less than 10,000 miles on them for $1500.
