10 spline C6
Old Mar 5, 2018 | 05:29 PM
74F100OKC's Avatar
74F100OKC
10 spline C6
I'm in the process of doing a manual to C6 swap in my 74 and I just picked up a C6 from a 1970 2wd bumpside the other day.
I got it home and it appears to be a 10 spline.
Is this rare?
Old Mar 5, 2018 | 06:07 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Scroll down to 7060 in these two truck parts catalog pics (1964/72 & 1973/79) and take a look-see.
Click on pics twice to enlarge them, then move them around w/the cursor.
Old Mar 5, 2018 | 09:25 PM
74F100OKC's Avatar
74F100OKC
Thank you sir. Now for the million dollar question that shows my inexperience. What' the easiest way to get the drive shaft on my 74 to mate with that style yoke on the c6? Have the driveshaft modified? Or is there a 10 spline replacement yoke that would match up?
Old Mar 5, 2018 | 09:32 PM
74F100OKC's Avatar
74F100OKC
Old Mar 5, 2018 | 11:03 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
You will need a Flange yoke to fit the yoke on the transmission that has the u joint size on your driveshaft. You should have a spicer U joint 5-153x. This is a Sample Flange number, this is for a 1310 U joint which yours should be. Not sure if the bolt dimensions are correct though. spicer 2-2-939
Old Mar 6, 2018 | 01:44 PM
74F100OKC's Avatar
74F100OKC
Thanks a bunch man I took the bolt on to a driveshaft specialty shop today and they found the flange yoke I needed for the 1310 U Joint I have.
Old Mar 6, 2018 | 03:13 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
Just make sure there is a slip yoke somewhere in the driveshaft. Can be in the front if one piece shaft. Needs to be in rear on two piece shaft.
351Cleveland C4
32
Jun 9, 2021 02:45 PM
68AZ
Jun 23, 2018 08:23 PM
kentruckf100
Oct 1, 2014 09:07 AM
hoxiii
Apr 13, 2006 08:01 PM
nickm
Jun 8, 2004 05:55 PM
