injector return line questions
Old Mar 4, 2018 | 05:15 PM
SgtOtaku's Avatar
SgtOtaku
So I just finished a month long project of replacing my entire fuel system with fresh hoses, and new brass fittings to make it all work. Now I have come across a problem with my return caps leaking. 4 out of 8 of my injector caps are leaking. I had replaced the caps and hose, but didn't have all the o-rings (the kit was missing one set), so some of the o-rings were not replaced. Would the routing of the return hose fittings, or the 6-psi carter fuel pump cause the issue? or is it more likely to be just the o-rings?
I do have a full set of o-rings on the way. In addition to my question above, can anyone give me a good, cheap method of removing and replacing the o-rings? they were giving me a hell of a time when I replaced the ones I had.
also, if pictures would help, let me know.
Old Mar 4, 2018 | 10:57 PM
SgtOtaku's Avatar
SgtOtaku
well, the original problem of not wanting to start is resolved. after much fighting and pain, and failed starts, the old truck finally roared to life and stayed running! i still have the injector cap leaks, so thats still an issue. But i'm looking into having some new caps made at a local CNC shop. any ideas on material? i was thinking aluminum, but may have to use brass...
Old Mar 5, 2018 | 01:45 AM
Charmalu's Avatar
Charmalu
Check out this thread where a guy made Brass caps.
https://www.ford-trucks.com/forums/1...rev-1-0-a.html
R&D IDI Performance has Billet Aluminum Fuel rails.
http://www.idiperformance.com/store/c4/Injectors.html
Mc
Master- Carr is a good source for the O-Rings
https://www.mcmaster.com/#9464K24
Charlie
Old Mar 5, 2018 | 02:02 PM
SgtOtaku's Avatar
SgtOtaku
That o-ring link is super helpful! I did see the brass cups article yesterday while searching for metal caps, and the r&d billing unit is awesome. But they are both out of my price range right now.
do you know if aluminum would work as an injector cap material?
Old Mar 6, 2018 | 03:17 AM
Charmalu's Avatar
Charmalu
The guy above that made the Brass caps, originally made a set out of Aluminum.
The guy he used to Aluminum weld the barbs in screwed the whole set up.
https://www.ford-trucks.com/forums/9...ps-update.html
Go down to pg 5 post# 73, he states the cost is $160 for a set. This is back in 2010.
This is all I could find Googling around.
For that price, you might as well go with R&D IDI Performance Fuel Rails.
Charlie
Old Mar 6, 2018 | 03:50 AM
SgtOtaku's Avatar
SgtOtaku
That's all I was able to find too. I don' even know if the guy who made the brass units is even still doing it... I may have to go with the r&d kit. But I'm a little weird, and I'm trying to avoid chrome and polished aluminum. Maybe they'll sell me an unpolished version of the rails for a little less money. Maybe. Well, guess I can only try.
Old Mar 6, 2018 | 11:54 AM
tradergem's Avatar
tradergem
What if you had the out side of the rails powder coated to look the way you want?
Old Mar 6, 2018 | 02:34 PM
SgtOtaku's Avatar
SgtOtaku
Will powder coating stick to billit?
Old Mar 6, 2018 | 05:11 PM
tradergem's Avatar
tradergem
According to the article here the heat for the curing of the powder coat can weaken the aluminum. Since the fuel return rails are not being used for their strength I don't see why you couldn't powder coat them.
Old Mar 6, 2018 | 08:35 PM
Charmalu's Avatar
Charmalu
Give it time under the hood and it will blend in with the other dirt, oil and grime...LOL
Charlie
dyoungen
Jan 27, 2017 01:56 PM
chillman88
Dec 6, 2016 08:29 PM
bassproguy07
Mar 28, 2007 08:58 AM
ALL BOY
Jan 23, 2006 09:11 PM
Davidson47274
May 23, 2005 10:31 PM
