Injector O ring
Old May 23, 2005 | 05:40 PM
Davidson47274's Avatar
Davidson47274
Injector O ring
My truck is getting air into the system and letting the fuel drain back to the tank, so I take it to a show to look at it and he shows me that around the top of the injector, the one under the fuel filter, is wet. He gave me a couple O rings and told me that might take of the problem. He also looked at my lift pump and said it looked good. Has anyone had this problem before and this worked? I changed my pump about a year ago. Oh this is in an 1988 7.3
Old May 23, 2005 | 10:31 PM
PLC7.3's Avatar
PLC7.3
My advise would be to get a whole new set of caps, line and orings. They are reasonably cheap at http://www.mwfi.com/ford_73.htm The one problem with changing only one injector's set of orings is you will disturb other caps and they will start to leak.........dog chasing tail routine.
Here is how to....
First disconnect injector cap nuts, "do not bend lines" but move them away enough to get the return line caps off as a complete set per side.
After removal of the complete return cap and lines sets, build new sets identical. To remove old orings use a dental or oring pick with a razor knife, do not mark the injector body. When installing orings use lots of grease and roll first one into top groove, then roll second over that to bottom groove. When installing the new lines and caps use grease inside the cap and on orings, place them on respective injectors and gently push straight down until it pops into place on the orings. Install the capline nuts 22ftlbs torque. There should be a small space between the return cap and line capnut when finished, any major leaks mean caps are not seated or orings are cut or line cap nut is not tight. I have done two sets lately and found bleeding 1-2 injectors at a time on opposite side the best, place fuel pedal to floor and fast idle and timing advance on, crank for 15 seconds, mine started after 4th injector was on line.
Note when cranking engine and bleeding there will only be a slight amount of fuel/bubbles seen, no major squirting gysers, that only happens with engine running at idle RPM.
Spectramac's Avatar
Spectramac
So does it start and die in the morning? It's a good idea to change them all, cuz if you disturb one they will all start to leak.
