Slip Joint Seperation
Old Mar 7, 2018 | 08:24 AM
pchelp's Avatar
pchelp
Originally Posted by Freightrain
Wow!!!! Crazy it took all that. Glad you got it fixed though.
It really does go to show how a little preventative maintenance once a year goes a long way
Old Mar 17, 2018 | 01:24 PM
JEFFFAFA's Avatar
JEFFFAFA
Ford has a special grease for slip yokes. Originally they called it "Teflon Grease". Under part number D2AZ19590A.
Now it is called PTFE Lubricant. sold in two package sizes. Also useful in eliminating squeaks between plastic parts and for speedometer cables.
3 oz tube part number XG-8.
1 lb container part number XG-8-A.
Old Mar 19, 2018 | 12:04 AM
GaryKip's Avatar
GaryKip
Glad you got it apart. I'm sure that by the time you finished cleaning and lubing it up, it will work smooth for the next 50 years.
Old Mar 19, 2018 | 09:46 AM
pchelp's Avatar
pchelp
Well I hope I didn't make a mistake but I liberally lubed it with Anti-seize when I resembled it.
Old Mar 19, 2018 | 12:42 PM
MIKES 68 F100's Avatar
MIKES 68 F100
anti-seize is PTFE . also called pipe thread paste, also cooking pan coating ..... available at Lowes ,Amazon..............
read up
https://en.wikipedia.org/wiki/Polytetrafluoroethylene
Old Mar 19, 2018 | 03:13 PM
pchelp's Avatar
pchelp
read up
The question is, will it hurt or hinder the operation of the slide yoke?
Old Mar 19, 2018 | 03:23 PM
MIKES 68 F100
no , I am sure you could use bearing grease . it's just there to keep metal on metal rusting
I used High temp bearing grease when i did mine .
Old Mar 19, 2018 | 03:30 PM
Tedster9's Avatar
Tedster9
Somewhere there oughtta be a Zerk fitting, to grease the splines.
No? Or did that go away at some point? There is on my slick. If you read the manual (I know, I know, crazy talk) iirc it mentions covering the outlet on the end of the D/S, to force the chassis grease into the spline area.
Old Mar 19, 2018 | 08:30 PM
pchelp's Avatar
pchelp
Yep, I spent over an hour cleaning out that old harden grease. It felt like coal, and smelled worse, once I could see daylight on the end the grease fitting was in I coated the splines with anti seize and reassembled it.
I also learned that you leave that grease fitting out until the very last ujoint is bolted in. Otherwise air can’t get in while you’re installing it. Once everything was bolted in I reinstalled the grease fitting added a little more and cleaned up.
1981 F100
Nov 22, 2018 08:10 PM
flamesoldier
13
Nov 18, 2014 02:53 PM
Vijay
15
May 28, 2014 04:49 PM
SuperDuty93
16
Dec 21, 2011 06:55 PM
FORDSDOWNER
Jun 5, 2011 04:52 PM
