Front driveshaft direction?
Old Dec 20, 2011 | 09:39 PM
SuperDuty93's Avatar
SuperDuty93
So when i went to look at my truck b4 i bought it, the owner had taken the front shaft off. I have a feeling he put it on backwards.lol Anyone have a pic of it in the correct direction? 1974 F250 4x4
Old Dec 20, 2011 | 10:24 PM
montana_highboy's Avatar
montana_highboy
The slip yoke goes up towards the the T-case....
Old Dec 20, 2011 | 10:32 PM
SuperDuty93
Haha its backwards then.lol What is the slip thing for?
Old Dec 20, 2011 | 10:42 PM
montana_highboy
When the suspension cycles up and down the drive shaft must be able to both extend and compress to accommodate this movement, hence the slip yoke.
Old Dec 20, 2011 | 10:53 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
When your suspension cycles in and out, the axle moves closer and further away and moves the r&p closer and further away from a fixed point, being the transfer case. You need a way to allow that movement in the drive shaft, hence the slip shaft.
And I believe there is S twist in the springs translated to the axle that changes the ring and pinion angle, and that in turn changes the length difference between the xfer case and the front axle.
The slip yoke allows for that length to change and still have power via the drive shaft applied to the front axle. That's why you have a rear slip shaft too, get it?
The short and long version......lol.
Last edited by 77&79F250; Dec 20, 2011 at 10:55 PM. Reason: Me and Mont HB were typing at the same time.
Old Dec 20, 2011 | 10:56 PM
SuperDuty93
Duh. I shoulda got that one my self haha. Now how big of a suspension lift can i go without getting a new shaft? Cuz since it would be taller, couldnt i max out the slip yokes extension length?
Old Dec 20, 2011 | 11:01 PM
montana_highboy
Exactly, generally speaking you can get away with about 3-4" of lift before you need to lengthen the drive shaft.
Old Dec 20, 2011 | 11:07 PM
SuperDuty93
ok sweet! I wana do 2" so it should work
Old Dec 20, 2011 | 11:19 PM
77&79F250's Avatar
77&79F250
2" All day long FoMoCo brother.....
Crazy tall and super flexy lifts without new length d/s can get you into a possibility of over extending you slip shaft and it coming apart ='s bad day.
Old Dec 20, 2011 | 11:25 PM
SuperDuty93
Haha ya i have enough probs, i dont need my shaft falling apart next
Old Dec 20, 2011 | 11:34 PM
77&79F250's Avatar
77&79F250
Keep in mind those slip yokes need maintenance like a u joint. Well maybe not quite as often, but at least a shot of grease every now and again.
Does yours have a grease zerk on it?
Old Dec 20, 2011 | 11:41 PM
SuperDuty93
If you mean the niple thing, ya i believe so. Do i use the same grease that i use for the rubber grease boots on the steering components?
Old Dec 20, 2011 | 11:50 PM
77&79F250's Avatar
77&79F250
Yes same as tie rod ends, ball joints, all u-joints (front and rear d/s) slip yokes. FYI some drive shaft u-joint do not have a zerk.
Old Dec 20, 2011 | 11:57 PM
SuperDuty93
Sweet. Ill be doing that 1st thing 2moro AM
Old Dec 21, 2011 | 12:01 AM
SuperDuty93
oh, i also nee to make sure my diff's have fluid. Any advice on how to check?
