Slip Joint Seperation
Old 03-04-2018, 03:04 PM
pchelp's Avatar
pchelp
pchelp is offline
Anyone have any tips on how to free up the slip joint? According to the shop manual the front drive shaft slides in on the splines.
Old 03-04-2018, 05:23 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Pic from 1973/79 catalog because there no pic like this in the 1964/72 catalog.
Old 03-04-2018, 08:20 PM
pchelp's Avatar
pchelp
pchelp is offline
8j
From what I can make out there is nothing holding it in, is that what you see?
Old 03-04-2018, 08:48 PM
NumberDummy
Remove the U-joint that retains the slip yoke to the rear driveshaft.
Old 03-04-2018, 08:58 PM
pchelp's Avatar
pchelp
pchelp is offline
But the carrier bearing is in the front half section, that’s what needs to be changed
Old 03-05-2018, 05:06 AM
mrpotatohead's Avatar
mrpotatohead
mrpotatohead is offline
Yes it just slides on. Sometimes the grease can put a little suction on it but after the grease cap is unscrewed it should just slide off. If there is a slight twist in the splines it might cause some issues.
Old 03-05-2018, 09:11 AM
MIKES 68 F100's Avatar
MIKES 68 F100
MIKES 68 F100 is offline
mine was stuck too , just drown it in Kroil,PB blaster,wd40 and let sit over night
i then had to tap it apart with a small hammer took forever . after ward i cleaned the splines with gasoline and a wire tooth brush .
Old 03-05-2018, 10:17 AM
pchelp's Avatar
pchelp
pchelp is offline
Man this thing must have never been greased !
Old 03-05-2018, 10:19 AM
pchelp's Avatar
pchelp
pchelp is offline
Yep, I used a tiny pick to remove as much of the old hard grease that I could then shot it full of PB Blaster. It's soaking now, I'll keep you posted.
Old 03-06-2018, 06:23 AM
GaryKip's Avatar
GaryKip
GaryKip is offline
Try using a 50/50 mixture of acetone and auto trans fluid to break it free.
Old 03-06-2018, 09:33 AM
Freightrain's Avatar
Freightrain
Freightrain is offline
Hammer time! LOL!! Ya, they can get stuck. A little persuasion can get it to slide apart.
Old 03-06-2018, 09:54 AM
MIKES 68 F100
now you had to say that
Old 03-06-2018, 08:23 PM
pchelp's Avatar
pchelp
pchelp is offline
HAHAHAHAHAHA 😂
Old 03-06-2018, 08:47 PM
pchelp's Avatar
pchelp
pchelp is offline
Ok here’s how I got it apart and replaced all the u-joints and got a new carrier bearing installed.
If anyone else wants to know how to separate a 50 year old slip joint, this is how I did it:
-clear out as much of the old grease as possible, enough to get some PB Blaster down the splines
-let it soak over night
-remove the grease fitting, pulling them apart creates a vacuum
​​​​​​-tie the ends of each yoke to something immovable I used two 500 lb tie downs and two opposing fence posts
-tighten as much as possible take two 5 lb hammers and tap evenly on each side, take out slack
-repeate until they pop apart
Hope this helps someone
Old 03-07-2018, 08:04 AM
Freightrain
Wow!!!! Crazy it took all that. Glad you got it fixed though.
Quick Reply: Slip Joint Seperation
