differential gear ratio
Old Mar 3, 2018 | 12:41 PM
Gstan's Avatar
Gstan
I have just purchased a 1993 F150 300 ci straight six auto, I'm going to use it to pull my bass boat to the lake. I have been trying to find out what the differential gear ratio is but I can't find anything. My thinking is since it will be a short haul vehicle (and I don't care about mileage) I might want to change the gear ratio to get a little better pulling power on the hills around my home. Any info. or thoughts on the subject would be welcome.
Thanks
Old Mar 3, 2018 | 12:51 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I have been trying to find out what the differential gear ratio is but I can't find anything.*
You have asked this question in the wrong forum, this one is for 1973/79 F100 and larger F series trucks.
You want to ask questions in the 1987/96 F150 and larger F series trucks forum.
*AXLE code printed on the Certification Label, glued to the left door face below the latch.
Rear axle ID tag located under one of the bolts that retains the inspection cover to the housing. If it's still present, it will have the ratio stamped on it.
Old Mar 3, 2018 | 01:55 PM
Gstan's Avatar
Gstan
OPPS!
Thanks, looks like it's a 3.08.
I'll repost in the correct forum.
They say when you get old the hands go first....that ain't true!
Gstan
Mar 9, 2018 12:59 PM
funkie49
Apr 22, 2007 09:41 PM
tucker2000
Sep 15, 2006 07:19 PM
BFR250SD
Jul 1, 2005 09:18 PM
ford78460
Jan 27, 2005 02:00 PM
