Gear Ratio
Old Mar 3, 2018 | 01:59 PM
Gstan's Avatar
Gstan
Gear Ratio
I have just purchased a 1993 F150 300 ci straight six auto, I'm going to use it to pull my bass boat to the lake. The axel code is "18" so it appears it's 3.08 ratio and the trans is an "E", 3-speed overdrive. My thinking is since it will be a short haul vehicle (and I don't care about mileage) I might want to change the gear ratio to get a little better pulling power on the hills around my home. Any info. or thoughts on the subject would be welcome.
Thanks
Old Mar 3, 2018 | 03:46 PM
Mudsport96's Avatar
Mudsport96
Here is a thread that should answer all your questions
300 i6 regear
a 3.55 would probablybe fine. And if you chose that, you may be able to find a whole rearend in the junkyard to swap and make the job easier.
Old Mar 3, 2018 | 05:57 PM
Gstan's Avatar
Gstan
Great Idea.
That sounds good. I can swap an axle but probably not the gears. Thanks for the link,
Old Mar 9, 2018 | 08:23 AM
Gstan's Avatar
Gstan
Update
I found an axle from a '93 4x4 at the salvage yard for $450. It's a 3.55 locking rear end so it sounds perfect.
Old Mar 9, 2018 | 12:59 PM
Mudsport96's Avatar
Mudsport96
Excellent, after the swap, update the thread to let everyone know how you like it.
Gstan
Mar 3, 2018 01:55 PM
engage
3.8 & 4.2L V6
Jul 4, 2015 07:00 PM
Broomfieldbum
Jul 26, 2009 09:07 AM
bain_b
1983 - 2012 Ranger & B-Series
Jan 28, 2008 02:55 PM
RushN350
Dec 22, 2005 05:16 PM
