Gear Ratio
Old Sep 14, 2006 | 09:30 PM
tucker2000's Avatar
tucker2000
Gear Ratio
I Have been looking everywere and cant find the gear ratio for my 1975 Ford F-100. Anybody offer any advice??
Old Sep 14, 2006 | 09:36 PM
RCrawler's Avatar
RCrawler
Look on the drivers door for a tag that lists the axle code. If you can get that code then we can figure out what ratio it should have.
Jason
Old Sep 15, 2006 | 07:40 AM
Torque1st's Avatar
Torque1st
Posting Legend
Check the Read First: FAQ thread at the top of the 73-9 forum for VIN and ratio info.
Old Sep 15, 2006 | 11:43 AM
MBBFord's Avatar
MBBFord
Welcome to the site. The door tag is the easiest way to tell, but if you can't read it, then there should be a metal tag on the bolts to the rear differential, and it should read somthing like this
3 50 4H84045J9
Which means 3.50 gears and the other numbers are build dates and locations.
Old Sep 15, 2006 | 05:21 PM
flcracker9's Avatar
flcracker9
If all else fails and you can't find a tag, jack the rear end up with the truck in neutral, and turn the tire exactly 1 full rotation, keeping count the number of times the driveshaft turns. Example: driveshaft turns 3 full turns, probably 3:08, 3.5 turns, probably 3:55, 4 full turns, probably 4:10 ect......
Old Sep 15, 2006 | 07:19 PM
Mil1ion's Avatar
Mil1ion
I used think that as well but sorry, that's been proven to be wrong.
Apparently It takes 10 turns to get the ratio right ...doing this turning while someone holds the other wheel (on open diff axle).
