Diagnostic code 213
Old Mar 2, 2018 | 03:40 PM
PagosaFord's Avatar
PagosaFord
Diagnostic code 213
I have a 92 f150 5.O l just checked my diagnostic code with koer pulled 213. The only reason I checked them was I was getting intermittent check engine light. Pulled codes 332, 328,327 this was koeo. To me it runs fine,
the gas mileage is bad. I know that is related to my egr issues. I need some suggestions on getting rid of the 213 code. I have never heard of a spout circuit. I looked in area where the connector was suppose to be found connector not attached, it has two wires, yellow green, and white red, could this be my spout connector. I sure can't find the other end. Any ideas?
Old Mar 2, 2018 | 04:45 PM
rla2005's Avatar
rla2005
If the gray shorting plug is missing, that is the cause of your Code 213 ( SPOUT circuit open )
courtesy of Subford
Old Mar 2, 2018 | 09:38 PM
PagosaFord's Avatar
PagosaFord
Picture of spout
Thanks for the picture, I'll take a good look at it tomorrow morning. As I said the truck runs fine.The mpg is not good.
Old Mar 3, 2018 | 06:53 AM
rla2005's Avatar
rla2005
With the SPOUT plug out the engine is running at base timing. Big contributor to poor mileage.
Old Mar 4, 2018 | 08:08 AM
PagosaFord's Avatar
PagosaFord
checked location of spout found it pulled it and checked continuity cleaned contact, checked codes still have 213. I don't known where to go next. As it said to me the engine runs fine, terrible mpg. Any other suggestions?
Old Mar 4, 2018 | 11:45 AM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
Next would be checking the ICM and related wiring.
Old Mar 4, 2018 | 12:00 PM
PagosaFord's Avatar
PagosaFord
the truck starts very well runs fine, everything I've read on the ICM would cause starting and running issues, I don't have that. Could it be that the timing is not correct. I have never checked it. I don't have a timing light, I have timed older engines with A vacume gauge. Can this be done on an EFI engine?
Old Mar 4, 2018 | 12:20 PM
sandymane's Avatar
sandymane
If you check the timing,. and I would, you remove the grey spout plug and time it to 10* BTDC. Then you replace the grey spout and the computer takes over from there. Plenty of videos and articles about how to time the truck. Sandy
Old Mar 4, 2018 | 02:35 PM
Da_Lariat_Chariot
You need a timing light to verify correct timing. It should advance if you leave the SPOUT connected and if you disconnected it the timing should not advance.
barnym17
Nov 24, 2017 08:25 AM
Carl Futch
Feb 18, 2016 04:53 PM
Two000F250
Oct 6, 2013 12:10 PM
suthrnslew
Sep 29, 2011 09:47 AM
The Chipster
Bronco II
Mar 18, 2004 06:57 PM
