spout open code
spout open code
I am getting a spout open code, but the spout is changing the timing when removed and reinserted.
Plus I am getting horrible mileage went from 15 to 10 mpg.Exhaust pipe is black, no visible smoke. truck is 1992 f150 4.9, cat has been removed exhaust is 2 in 1 out muffler I think the shop took a 2 out 1 in muffler and installed it reversed.
Also have an egr code, the truck runs great it's just mileage is killing me any ideas appreciated.
I believe Code 18 is a CM or KOER code. Assuming it's from CM the definition is IDM circuit failure or SPOUT circuit grounded..
Since the timing is changing when the SPOUT is in my money is on an IDM problem. IDM = Ignition Diagnostic Monitor.
We had a recent thread on this topic: https://www.ford-trucks.com/forums/1...in-memory.html
Code 212 is the same as the two digit Code 18...
For reference:
The item labeled as Ignition Suppression Resistor is how the IDM signal is buffered then sent to the computer. In the thread I linked to the OP replaced it after diagnosing the issue as an intermittent open in the IDM circuit.
For reference:
code update rescanned with modis after work,
Koeo
1. 332
Koer
1.412
2.213
3.332
4.225
Thanks for the help guys alldata not much help on this one so far, My wife thinks I'm nuts for working on my old girl instead of replacing , but she only has 248,00 miles lot of life left in her I think.
Koeo
1. 332
Koer
1.412
2.213
3.332
4.225
332 is not a valid 1992 KOEO code. Maybe a bad code reader.
Maybe a CM Code?
412 EOER:
Service Code 412 indicates that during Engine Running Self-Test, engine rpm could not be controlled within the Self-Test upper limit band.
Possible causes:
-- Open or shorted circuit
-- Throttle linkage binding
-- Improper idle airflow set
-- Throttle body/ISC solenoid contamination
-- Items external to Idle Speed Control system that could affect engine rpm.
-- Damaged ISC solenoid
-- Damaged processor
KOER 213: CHECK FOR POWER TO PROCESSOR
I do not think you are not getting the codes read right.
Maybe a CM Code?
412 EOER:
Possible causes:
Plan for today is tuneup just because,lol. Then test all codes using the troubleshooting procedures in alldata. will report back on what I find.Thanks for the help.
Priced a new truck optioned like Bessie and for the $40,000 price tag I can do a lot of repairs on the old girl she is in process of a 3.08 to 3.55 l/s swap, bed swap, and thinking of rear spring upgrades.
TramCommon
11-25-2016 07:28 AM
trdsmn
12-10-2013 08:19 PM
