6.2L V8 Discuss the 6.2L V8
no cold start issue
Old Mar 1, 2018 | 02:37 PM
tjc transport's Avatar
tjc transport
i ain't rite
no cold start issue
my 2014 6.2 truck sometimes will not cold start. almost like a carburetor engine that is flooded.
only way to start it is to step on the throttle while cranking over. once started and running for about 30 seconds it is fine.
just picked it up from dealer who tried to charge me $185 diagnostic fee to tell me there is nothing wrong with it because their computer did not find any problems, so i could bring them out and show them there is in fact something wrong with it when it would not start in the parking lot until i steppedon the throttle.
they then started with the "well we can change the tps for $432, the coolant temp sensor for $126, clean the throttle body for $348, but there is no guarantee it will work.
that was about the time i called them friggin parts changers and not mechanics and left.
anyone have any ideas? once started the exhaust stinks of unburnt fuel for a few minutes, just like a flooded engine does.
Old Mar 1, 2018 | 03:26 PM
82_F100_300Six's Avatar
82_F100_300Six
Just a hail Mary I have no idea but maybe you can clean your MAF or MAP sensor ?
Old Mar 1, 2018 | 05:15 PM
Homerunking2394's Avatar
Homerunking2394
Idle air control valve no opening enough?
Old Mar 1, 2018 | 05:35 PM
tjc transport
i ain't rite
it does not do it all the time. may not do it for two weeks then happen 2 times, or ten times. then not happen again for a few days or weeks.
it has no rhythm or rhyme.
the MAF and MAP sensors were cleaned just before christmas when i also cleaned the throttle body and replaced front hub seals to get did of a vacuum leak.
that cleaning and repair netted me close to 3 MPG gain in fuel mileage.
the truck has 96,000 miles on it.
Old Mar 1, 2018 | 06:09 PM
Homerunking2394
if it can't start one day, unplug a sensor and try again
Old Mar 2, 2018 | 08:32 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
You need a IAC , if its sticking when cold it won't show up on any code. One of my V10 did the same thing but only when cold.
Denny
Old Mar 2, 2018 | 09:13 AM
Chuck's First Ford's Avatar
Chuck's First Ford
Denny
I agree....
maybe try cleaning the IAC first... or just replace.. my opinion. ( sticking or bad ) and NO Codes.
Idle Air Control valve.
I also agree..... parts replacers..... not mechanics... New repair shop in your future.
Old Mar 2, 2018 | 12:12 PM
tjc transport
i ain't rite
i was just looking for iac and according to the internet there is no iac on the 6.2.
i am going to have to call my local ford parts dude.
Old Mar 2, 2018 | 12:31 PM
Chuck's First Ford
if no iac..... look for temperature sensor for computer .. not for engine temperature gauge...
could be in air or cooling system..
I do not have my book handy...
injection system needs to know outside and engine temperature for starting.... richer for starting... leaner after a minute or 3 later...
for many years the japan built cars .. had 2 sensors...
Old Mar 2, 2018 | 12:36 PM
Homerunking2394
Interesting....
Old Mar 2, 2018 | 01:20 PM
82_F100_300Six
Translate a stuck choke to fuel injection. Whatever that would be.
Old Mar 2, 2018 | 02:30 PM
tjc transport
i ain't rite
it is really screwy Chuck. and very confusing.
with the old mod engines, 4.6,5.4, and 6,8 thus condition was usually caused by a bad engine temp sensor.
so i went to ford to get a temp sensor because no parts stores or sites list a coolant temp sensor.
as per my parts guy, that is because the 6.2 does not have one.
he said the computer uses cylinder head temp and engine oil temp to determine coolant temp.
DJayAce
2004 - 2008 F150
Apr 6, 2020 07:30 AM
freegdr
2004 - 2008 F150
17
Apr 13, 2011 08:25 AM
specializedcc
Modular V10 (6.8l)
Dec 21, 2008 12:13 PM
ozoner
3.0L V6
May 2, 2006 10:48 PM
xp8103
Jun 20, 2002 07:53 PM
