cold start prob
Old Jan 28, 2011 | 09:56 PM
freegdr's Avatar
freegdr
cold start prob
94 f250 cold start prob will only start when fuel is squirted in to throttle body/air intakes ?
Old Jan 29, 2011 | 07:22 AM
shorebird's Avatar
shorebird
We need more info please.
What engine? 4.6L 5.4L
What happens after it starts?
I just noticed you wrote F-250.
Try the SD forum.
This is the '04-'08 F150 forum.
That's why nobody has answered.
Old Jan 29, 2011 | 07:53 AM
Greg B's Avatar
Greg B
Could be an Idle Air Control Valve problem. It's on your throttle body. Try removing it and cleaning with MAF and Throttle Body Cleaner.
Old Feb 1, 2011 | 03:40 AM
freegdr's Avatar
freegdr
5.8 clen iac new plug wire cap rotor if you sguirt fuel in the throttle body it starts then keeps searching for idle
Old Feb 1, 2011 | 03:42 AM
freegdr's Avatar
freegdr
Try the SD forum.
ive listed it in 4 places looking for a ford mechanic year dont matter that much if you no the fix
Old Feb 1, 2011 | 06:43 AM
shorebird's Avatar
shorebird
I do not know of a Ford 5.8L.
Old Feb 1, 2011 | 03:18 PM
freegdr's Avatar
freegdr
thanks any way for the answer
Old Feb 1, 2011 | 03:20 PM
freegdr's Avatar
freegdr
94-97 Ford 351 / Ford 5.8 Engine (Part #: FORD-351WRLB)
Old Feb 1, 2011 | 09:37 PM
Greg B's Avatar
Greg B
Any codes? How does the fuel system check? Does it start if you hold the accelerator pedal to the floor? Does it smell rich after starting?
Old Feb 2, 2011 | 12:26 AM
freegdr's Avatar
freegdr
no codes all started after using that sea foam crap in fuel system and pouring in vacuum lines, truck will start if fuel is squirted into air intake then searches for idle, have not tried pedal to foor yet, its rich when trying to idle,will bei checking fuel system just trying to get all areas to check for probs for this weekend s work
Old Feb 2, 2011 | 06:10 AM
ojai150's Avatar
ojai150
Maybe the inertia switch got set off....
Old Feb 2, 2011 | 07:05 AM
kevincw's Avatar
kevincw
I would start by checking for vacuum leaks. Than I would look at the IAC. Why did you Seafoam in the first place? Was the truck running poorly or missing?
Old Feb 2, 2011 | 07:12 AM
Greg B's Avatar
Greg B
Accelerator to floor when starting cold might help cold start. Sounds like it's flooded out for some reason. Probably IAC. You can remove it and clean with MAF/ throttle body cleaner. That might do it. Or you may have to replace it.
Old Feb 6, 2011 | 10:05 AM
freegdr's Avatar
freegdr
we have to add fuel to get it to start
freegdr's Avatar
freegdr
cannot get codes neiter test will produce any self or meter
