Practical Jokes
at work. I have a good supply of zip ties for driveshafts. But after that i am stuck. Share your personal stories if you have them. Thanks.
After a while it stinks bad and most people won't think to take off the hubcap to check there. A fish under a top tool box works awesome too.
Instead of zip ties on the driveshaft use stick-on mag wheel weights...they shake really good
We hooked up one of our receptionist's horn to her brake light switch. That was pretty hilarious.
Friction modifier on a rag under a seat stinks bad.
One thing that we havent done in our shop in a while is to take an antifreeze jug, drill a hole in the cap and put in an air fitting. Hook an unplugged airhose up to the fitting then slide it under the car they are working on and plug in the airhose into the fitting on the wall. The jug explodes nicely
One of our techs hit his head on the underside of the hood and almost knocked himself out when it happened to him.It happens lots in our shop that you're using a cutting torch and someone will come along and shut off the oxygen.....really gets quite annoying.
One of our shop runners took a piece of 1 inch flat bar and wrapped it around a tech's toolbox and welded it shut. That was a good one.
2 other words......styrofoam peanuts
In toolbox drawers, heater ducts, exhaust pipes etc etc.
The mechanic rerouted the windshield washer hose back inside the cab and tied it to the underside of the steering column, pointing it at the crotch area of the drivers seat. He then rewired the washer pump to the brake light circuit so when the brakes were applied, the pump would come on. Since the driver always left about 2:00 AM, it was dark and it took him awhile to figure out why he was getting soaked in a sensitive area with a alcohol based liquid
Jared
Hmmmmmmm thats a good idea!*thinks to self(I know just the person to pull it on)*
http://www.clubfte.com/users/thewiz427/santa_merry_christmas_md_wht.gif
Wiz
[link:www.clubfte.com/users/thewiz427/index.html|"Wiz's Place"]
before that had an unsolveable clunk when accelerating a braking. After driving the car, it sounded like something was in the passenger side door. When I pulled the panel off, there was a large nut in there, I think it was like 3" across. Chrysler came and took it back to the factory, and gave the guy a new car. It turns out they had had some problems with pranksters, and so far had found three or four vehicles like this.
Another great trick is to take all the trim off of the guy's car, including the grill, and leave it all on the front seat.
Jared
Nathan
TM
.We did this to the highschool drama teacher. She had a ricer with a sun roof. She never locked the car so we got in let this real skinny kid use duct tape to wrap both inner door handles together so nither door would open from the outside. we used almost an entire role. Then the kid climbed out through the sunroof.
Next time you are the dd and taking your drunk passed out friends home. Find a nice spot on the road make sure there are no cars around and slam on the breaks and start scremin. I had one friend **** himself.
You office types can pop off the keys on the keyboard and rearange them.
Small cars and be picked up and turned between things with a few people. Such as other cars, trees, fense posts,
You can remove toolbox drawrs and rearange them.
steel the wheels of desk chairs.
If you get a role of caution tape or anything like it. Tie one end under the back of someons vehicle and stuff the rest of the role up under the frame somewhere so it will fall out on the drive home.
just some things to think about
I called and told her I was with animal control and that I had just caught her dogs running down the road. I described them to her (you need to know them well obviously) and said that because one of them had bitten a person they would all be put down if she didn't come quickly.
She was just about out the door- already punched out before I could stop her. I laughed pretty hard, especially since I had used my real name when I called.
Also she lived alone so she was trying to figure out how the dogs could have opened the door.
Another good one is to have them "catch" you talking to a friend about how the hottest chick at work was asking about them. When your friend walks up, act like you don't want to talk about it and make him force you to tell him that she was asking if he was married. Make him promise not to tell her you told him, then sit back and watch as he puts himself in awkward positions with her.
Also you could take him out for a drink and have a couple of friends play the joke on him. Have a lady friend come and sit next to him at the bar (she ignores him) then have the biggest guy you know come in and accuse her of [link:https://www.ford-trucks.com/guidelines.html|FTE Guideline's] your friend.
As your friend turns to say that he doesn't know what the guy is talking about, have the girl say something like "well you don't own me and he treats me better than you anyway. Stand back and watch the backpeddling begin. Good one because you get to humiliate him in public
Have a fake contest where you are giving a friend a dollar every time he can do it. Then when the pigeon puts his head back and places the nickel on his nose, pour your coffee in the funnel.
A little too much for you? You're the Prussian blue on the telephone or shift **** type, try this.
First show off the raising arm trick. Stand next to a wall or doorjamb with your arm at your side, press out with the back of your hand for 20 seconds. Then step away and relax and your arm will float up in the air. Then pull your gag.
Requiring some assistants. You explain to a guy (he's in on it) that if he lays down on the floor and you lay a wool military blanket over him, if you rub the edges and rip it off real fast he won't be able to sit up from the waist for the first two seconds. When he tries, cover him with the blanket, rub the edges to create this magic static electrical tractor beam, jerk the blanket off and he can't break the bond of the static electricity (because he is in on it.)
Now it's the dupes turn, he thinks he can do it. Cover him with the blanket, rip it off and he will sit up at the waist very fast because it doesn't hold anything but he's using force to win the dollar. But you have someone standing over him, facing in the same direction, bent over with shorts dropped. When his face hits the butt, everyone else takes pictures or laughs.
I got a million of 'em. Don't tell me I didn't learn anything in 20 years of military.
