Sponsored by: Auxito
Key programming unsuccessful
Old Aug 2, 2018 | 11:14 PM
hrsetrdr's Avatar
hrsetrdr
Originally Posted by projectSHO89
Well, duh! You have to have TWO UNIQUE keys in order to program more using the owner's manual procedure.
Well give yourself a "DUH" for misquoting my post, you left out "I speculate" I guess to make my statement sound stupid.
Old Aug 3, 2018 | 02:00 PM
hrsetrdr's Avatar
hrsetrdr
I doubled checked whether this is a PATS1 or PATS2 system, appears to be a PATS2. Downloaded the F-150 manual to double-check the specific procedure.
Procedure to program spare SecuriLockY keys to your vehicleNew SecuriLocky keys must have the correct mechanical key cut for your vehicle.Conventional (non-SecuriLocky) keys cannot be programmed to your vehicle.You will need to have two previously programmed SecuriLocky keys andthe new unprogrammed SecuriLocky key readily accessible for timelyimplementation of each step in the procedure. Please read andunderstand the entire procedure before you begin.1. Insert the first previously programmed SecuriLocky key into theignition and turn the ignition from OFF to RUN (maintain ignition inRUN for at least one second).2. Turn ignition to OFF and remove the first SecuriLocky key from the ignition.3. Within five seconds of turning the ignition to OFF, insert the secondpreviously programmed SecuriLocky key into the ignition and turn theignition from OFF to RUN (maintain ignition in RUN for at least onesecond but no more than 5 seconds).4. Turn the ignition to OFF and remove the second SecuriLocky key from the ignition.5. Within 10 seconds of turning the ignition to OFF, insert theunprogrammed SecuriLocky key (new key/valet key) into the ignitionand turn the ignition from OFF to RUN (maintain ignition in RUN for atleast one second). This step will program your new SecuriLocky key.6. To program additional SecuriLocky key(s), repeat this procedure from step 1.If the programming procedure was successful, the new SecuriLockykey(s) will start the vehicle’s engine. The theft indicator (located on theinstrument panel) will light for three seconds and then go out.
Repeated the procedure verbatim . Unsuccessful. I did everything correct, it does appear that the two keys I've had for the truck since I bought it must be clones, and not unique.
Looks like options are limited, I might be up for the "PATS bypass" procedure, just noticed the rubber boot for the shifter has rotted, so might be a good time to get my hands dirty.
pirate4x4_camo
May 21, 2024 01:19 AM
ssharber
6.4L Power Stroke Diesel
Jun 25, 2015 05:11 PM
DirtySCREW
Escape & Escape Hybrid
Nov 12, 2013 06:56 PM
tapout
1997 - 2003 F150
Sep 14, 2006 06:49 AM
Mr.D
Feb 22, 2006 12:48 PM
