Hi
looking to take out my side glass to measure it up for replacements to be cut, cant see how to take just the roll up/down glass out without stripping the whole door down, is there an easy way to do this without disturbing the vent window etc.
The vent window frame comes loose pretty easy and only needs to tip a little, not come out, IIRC. It's not a bad job. Order some new rollers and replace that while it's out. Also a good time to pull the window regulator mechanism, clean and lube it up good.
