Tranmission Question
I would assume there's going to be a slight difference in length going from an SROD to a T-5 --with the T-5 being slightly longer, since you would be going from a 4-spd to a 5-speed transmission.
The T-5 was first put in the Mustangs around 1983. The World Class T-5 was introduced in 1985 but the more improved versions were from 1990-1995 although, '94/'95 models will be slightly longer than the previous models (deeper bellhousing).
A regular 5.0L Mustang GT T-5 will have a 3.35:1 1st gear ratio and a .68:1 overdrive ratio. The '93 Cobra/Z-spec T-5 will have a 2.95:1 1st gear ratio and a .62:1 overdrive ratio.
Pick a T5 out of a fox chassis Mustang. 1983-1993. Later ones better than the earlier ones. In 1983 Ford put both the 4 speed SROD and the 5 speed T5 trannies in Mustangs. Both trannies took the same part number of driveshaft yoke. But the complete driveshaft part numbers were different. This leads me to believe the two driveshafts were different lengths. I can't tell how much however.
on
From googling, it looks like the T-5 is longer than the SROD, as Jeff alluded to. It also appears that the T-5 requires a different bell housing. IIRC Mustang bell housings use a cable clutch which won't work with your mechanical clutch. Contact the T-5 experts at Modern Drivelines and ask these questions.
fordpower46
04-25-2009 06:48 PM
BaronVonAutomatc
04-13-2007 09:13 AM
Scott_in_Canada
07-03-2003 04:39 PM
shons b2
10-03-2002 09:19 PM
