Headlights dim at idle
Old Feb 21, 2018 | 02:31 AM
bri687's Avatar
bri687
So I'm having a problem with my 2003 E150 headlights dimming at an idle after the van has warmed up. If I rev up the engine the lights go back to normal. Also today I went for a hour drive stopped for ten minutes and it wouldn't start. I got a jump start and bought a new battery.
Old Feb 21, 2018 | 12:05 PM
Thenne1713's Avatar
Thenne1713
It could have been a symptom of the failing battery, so check your charging voltage; u can find required voltage on the internet, or Autozone or others will check for free? Also make sure terminals are clean.
Old Feb 21, 2018 | 12:39 PM
Sparky83's Avatar
Sparky83
could also be the alternators going.. autozone, advance and oreillys can all do in-vehicle charging tests...
Old Feb 21, 2018 | 08:01 PM
kennyfzj80's Avatar
kennyfzj80
If it is still doing the same after new battery, I would look into the alternator.
If not the alternator, maybe some wiring/shorting some where.
Old Feb 21, 2018 | 09:54 PM
Thenne1713's Avatar
Thenne1713
One additional thought is, if v-belt driven alternator,
belt maybe loose/ slipping
Old Feb 21, 2018 | 10:08 PM
CWR032's Avatar
CWR032
It sounds like a failing alternator, but the battery light on the dash should be coming on. I just replaced the ne on my work van (Twice, thanks to AutoZone) for the same symptoms.
Old Feb 22, 2018 | 12:02 AM
maples01's Avatar
maples01
It is either battery or alternator but I'll go out on a limb and say check your grounds, engine to frame and to battery. BTW I had a fluctuating gauge at WOT, all tests came back inconclusive, I started ignoring it, about a year later the alternator failed, had an internal short, I got it built by a shop nearby, they increased the amperage with better internals.
Old Feb 22, 2018 | 08:24 AM
Im50fast's Avatar
Im50fast
A bit of a long shot but have you looked into the DRL module? Or are you describing symptoms that apply when the headlight switch is on?
The DRL module is supposed to turn on your headlights (only, not including parking/marking lights) at reduced brightness.
When mine went bad it caused the headlights to flash similar to a police car.
Old Feb 22, 2018 | 11:34 AM
wirelessengineer's Avatar
wirelessengineer
Always a good idea to check grounds, but folks, keep it simple. Do the basics first.
Check the charging voltage. It's as simple as putting a meter on the battery while it's idling. You should see about 13.8 volts.
OR, as suggested, go to one of the chains and get it tested. Free, easy, and pretty reliable.
Basics first.
Old Feb 22, 2018 | 01:12 PM
Im50fast's Avatar
Im50fast
Basics first.
truth! Truth
Old Feb 22, 2018 | 07:09 PM
bri687's Avatar
bri687
I took the van to advance auto and got a load test that says no load 12.68 loaded 12.38. So I do think its the alternator but is there a separate voltage regulator if so where is it located?
Old Feb 22, 2018 | 07:26 PM
maples01's Avatar
maples01
The regulator is on the back of your alternator, be aware, you could have a diode going bad before deciding to just replace the regulator.
Old Feb 22, 2018 | 07:31 PM
bri687's Avatar
bri687
What is / where is the diode that you speak of?
Old Feb 22, 2018 | 07:35 PM
maples01's Avatar
maples01
It is inside the alternator itself, requires complete disassembly, a good shop that builds them is your best bet.
bnuvp
May 21, 2017 06:29 PM
Rusty_Old_F250
Apr 19, 2010 05:24 PM
eukel
Electrical Systems/Wiring
Jul 15, 2009 09:06 AM
ford f-200
Jan 17, 2009 12:27 AM
Paul_W
Nov 7, 2003 12:05 PM
