Big Deal?
Old Feb 18, 2018 | 06:17 AM
hanklin's Avatar
hanklin
Big Deal?
SES light came on and is throwing PO472 EBP. Is the need to fix now or can it wait? Timing with work schedule is bad. I am straight piped (no cat or muffler). Did not run any differently, for the 4 miles, but am leary of what could be.
Thanks
Old Feb 18, 2018 | 08:28 AM
BBslider001's Avatar
BBslider001
You should be ok as long as the butterfly isn't getting stuck closed. That may be the code for the sensor though as well, which is also not a big deal. Just get to it when you can. Truck run any different? I have had this code pop up, but it's a soft code, so no CEL. I replaced the sensor and all is fine.
Old Feb 18, 2018 | 10:58 AM
pirschwagon's Avatar
pirschwagon
At the base of the Turbo there is a Plug which controls the EBPV. You can flip the wire lock up and remove the plug. This will prevent any activation and the Spring will keep it open. Unplug the Connector at the EBPS.
It's not the end of the world. Just some troubleshooting when you have time to determine what the actual issue at hand.
Remember your Engine will not reach Operating Temperature as quickly as it does with the Valve. So, no Right Foot through the Floor Board before it's warm.
You'll be fine.
Old Feb 18, 2018 | 01:03 PM
Hussler's Avatar
Hussler
P0472 Exhaust back pressure sensor circuit low input
What that means is the PCM is detecting a voltage lower than expected at the lower end of the scale. Probably just a bad sensor. If you unplug the sensor you will probably throw the same code. Won't hurt anything.
Old Feb 18, 2018 | 03:59 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Worth checking for soot buildup in the tube and on the sensor. To prevent tweaking the bracket stabilize it with a second wrench while removing the sensor. A bit of trimmer string fed thru the tube can clean the gunk. Tubes also rust thru so inspect as well as possible. Cleaning the sensor don't be too enthusiastic as they are a bit fragile up in there.
If the sensor is not providing good info to the PCM it will hurt your fuel mileage.
Old Feb 19, 2018 | 01:57 AM
hanklin's Avatar
hanklin
Thanks for help.
I'm going to pull sensor tomorrow hoping that is the culprit. Gotta figure with 430k on the odometer it is probaly time.
Old Feb 19, 2018 | 07:32 AM
pirschwagon
With that mileage, I would be willing to Bet the Tube needs replaced. They rust through and don't build enough pressure.
Old Feb 19, 2018 | 08:26 AM
BBslider001
The sensor is about $80 and the tube from Dorman is $30 or something like that. Mine was rusted in half. I replaced it with a Dorman and it's been good for a year. It's still shiny and new looking LOL
HighSilver
May 17, 2019 06:08 PM
stinson 108-1
2009 - 2014 F150
May 3, 2019 06:10 AM
Brian460
Mar 9, 2015 08:56 AM
95psd
Jan 8, 2006 01:09 PM
sprgiles
Oct 27, 2003 10:52 PM
