My 13 3.5 eco has the bank 2 sensor 1 oxygen sensor code p0151. I want to replace with an oem sensor which I believe is pre cat located on the driver side below the turbo. Anyone know for sure, have a part number?
Go to Tasca.com and enter all the relevant vehicle info and you'll be able to source the part you need.
I just had the same O2 sensor replaced at the dealer because my shoulder is jacked at the moment. Turns out that the bank 2 sensor is the more expensive of the two. It apparently has a longer harness but it was only 30 minutes of labor for them to do it.
