2003 6.0 Power stroke
I replaced the ICP sensor and the pig tail however after clearing the code Everytime the truck is started the code for ICP circuit voltage low sensor comes back. The idle surging symptoms I had before changing the sensor went away with the new one.
Mark I don't know where he is but if he is local to me I may be able to arrange something.
I agree we need to know what the DTC is. It will run without the sensor plugged in and kick
out a code to tell you that.
Meaning that with no input from the sensor the PCM will go into a default mode that has noting to do with a tune.
It is guessing at what it thinks it should see not any real sensor data.
