Solid side window
on
you do have to cut part of the inner door liner away. This is the curved panel that surrounds the upper hinge. Here's a copy of an article on the one piece install from Street Rod Builder magazine and then some pics of my door.
I used a kit from Mid-50 F-100 midfifty.com
this isn't a particularly hard upgrade but it's tricky..
john
john
on
the piece you're holding is the lower window track.. yours doesn't appear to have a tab on it that would bolt to the outer door hinge ?? see pic below. That secures the track on mine.
Also I cut a larger hole in my inner door to have more access to make the cut in the inner liner, then replaced it leaving access to the hinge bolts
these are some more random shots and instruction pages that might help..
on
on
I used the hole above the door handle for the upper mount of my window motor track.. from the latch end of the door to the center of that hole is 15".
My track is stationary and mounted in this upper hole and in a flat bar mounted across the door inspection cover opening
also I used bear claw latches and there was plenty of room for a latch... the window track mounts to the outside of the latch... see pics
john
john
john
john
on
no outside handles... solonoids operated by remote. the actuators are mounted in the lower part of the door and pull the release on the bear claw latches
https://jniolon.classicpickup.com/be...awlatches.html
Don Vito
04-08-2017 06:50 PM
toofazt
10-18-2012 12:31 AM
Fyrhosr
08-11-2012 06:24 PM
superman64011
52
03-05-2011 09:14 PM
superman64011
10-28-2006 08:18 PM
