One Piece Side Window ?? 1955
Old Oct 17, 2006 | 11:21 AM
superman64011's Avatar
superman64011
Has anyone installed the One Piece Side windows in a 53-55? What kind of mods did you have to make? Where did you get it from? Did you like it? How difficult was it? The usuall ??. I might be putting one in.
Thanks
Patrick
Old Oct 17, 2006 | 11:36 AM
sdetweil's Avatar
sdetweil
I just finished this.
there are two 'hard' spots..
1. folding the tabs down in the window channel after you cut them.
2. cutting one little section of the door interior. (hard to get to)..
I used a plasma cutter on one door, and a reciprocating saw on the other.
it was easier with the saw in the end.
I installed power lifts too, and all is well..
It took me 3 hours for the first door, and 1 hour for the second door.
I am switching doors to a set needing less repair, so I have to redo this again!
I got the kit from Midfifty
one kit mod, use the little metal plates to align the front door channel further out into the window space to make the felt chrome trim show the same all the way around the window space.
I can take some pics
Sam
Old Oct 17, 2006 | 01:47 PM
superman64011
If you didnt like it could you change back to the Vent or would it be to difficult?
Patrick
Old Oct 17, 2006 | 01:52 PM
sdetweil's Avatar
sdetweil
you have to cut the tabs that hold the inner and outer door pieces together, and remove one piece..
It would be a pain, but I suppose you could put it back..
The inner door face is cut up, so you wold have to use door panels..
Sam
Old Oct 17, 2006 | 08:54 PM
EFFIE49201's Avatar
EFFIE49201
Smile one piece glass
I met these guys at the supernats in 04. had a one piece glass set that required no modifications to the door. was curved glass. Was $295 then now on website $250
www.vintageglass.com
Old Oct 17, 2006 | 10:36 PM
sdetweil's Avatar
sdetweil
That $250 is for the 56 door glass, a lot easier than the 55..
I don't know how you would do a 55 with complete one piece glass without moding the door interior bulkhead. You CAN do an almost complete one piece, with the little filler in the front corner so that you DON'T have to mod the door..
Sam
Old Oct 18, 2006 | 01:12 AM
superman64011
Thanks alot for the Info Fellas...
Old Oct 28, 2006 | 05:43 PM
sdetweil's Avatar
sdetweil
I just updated my gallery with an album showing this kit install (one door).
Sam
Old Oct 28, 2006 | 08:18 PM
54fever's Avatar
54fever
Very nice sdetweil! you make a one piece window installation seem very easy with your step by step instructions and pics.
pcpotter1023
Dec 10, 2015 01:03 AM
Patrick R.
General Automotive Discussion
Sep 26, 2015 11:46 PM
charpentier
New Member Introductions
Jan 1, 2015 01:10 AM
hoverp
6.7L Power Stroke Diesel
Mar 19, 2014 11:24 AM
74F2504by4
Mar 12, 2012 12:10 PM
