I'm new to the forum and may have originally posted this on the wrong page. I have a general question about towing 5th wheel toy haulers. At what trailer weight and/or length should you be towing with a DRW truck vs a SRW truck? Thanks
You'll get a lot of different answers about this. My trailer is 39' long with a pin weight of 3050 lbs. I pulled it with son in laws F-250 SWB but it exceeded the trucks payload and before damaging his truck I went and bought a F-350 DRW and couldn't be happier towing our trailer. Maybe could have gotten by with F-350 LWB but I rather have the 4 wheels on the ground for more stability on the hwy. Match trailer to the tow vehicles payload and leave some cushion and you should have no problems. I'm 16K pounds gross weight on the trailer.
Search the forum(s) - has been asked and answered many times. There is a formula that has to do with the GVWR and individual axle weight ratings of your truck (available from the truck's door sticker), the actual weight(s) of your truck (your local CAT scale for this one), and other factors. To keep it simple, you can handle a fifth wheel that is 4 times as heavy as your leftover payload for the truck.
With the new SRW trucks right now the limitation is usually pin wieght, not the trailer wieght or length. Some 40 footers will be fine with a SRW, others will need a dually.
A general rule of thumb is have a matching number of tires, but there are exceptions.
My trailer has a pin wt. of about 2750 when in battle trim. Thats all I'd want to put on a SRW, assuming the 11,500 GVWR package. It leaves enough room for occupant weight and the typical camping stuff that goes in the truck bed. If you're looking at something in the 40' range, get a dually and don't look back.
The difference between towing with SRW compared to a DRW comes out the first time you get into a good stiff side wind not the tow rating of the truck when you are talking about pulling a high profile trailer.
As Denny said. Cross winds with a large fifth wheel and you will definitely have a white knuckle drive with singles. I enjoy the solid drive with the duals
Always better to error on the side of safety; if you're gonna be close, go DRW. If you're gonna be way under (aka a 26ft 6k lb 5th wheel) then go srw. Like others said; winds are gonna make you wish you had a drw. There are 2 other points to bring up: 1, you might get a bigger trailer in the future. 2. you can get the F450 or another widetrack truck (f350 with that option) that will let you turn that giant trailer much much much better. My truck doesn't have it, and I can tell you backing in a 39ft trailer sucks.
Thank you all very much for your feedback. I know it is individual opinions, but they are based on a lot more experience than I possess. I would have never thought about the turning radius issue if someone hadn't mentioned it. To me that is the beauty of these forums. I am going to "error" on the side of safety and go with the DRW. Now to the Ford dealer. I'll try to remember to post a picture when all is done.
Bull. I have never ever ever had a white knuckle ride with our 5th and SRW. and I have more miles then most, we move every week or two.
45’ 15k dry 20kgross 2900 pin with plenty of space in the back for them heavy toys to load and level out the rig. Anything is Possible . Just buy what you enjoy. After I tow the load I like to disconnect and use my rig for what it was designed to, go explore. I knew what I was getting into so I ordered a 350 srw with all the towing options out there .
