Relocating High mount Camera??
Old Oct 11, 2018 | 01:11 PM
dthrckt's Avatar
dthrckt
They replied and need to see the connector disconnected. If no one sees this and has a pic I'll disconnect mine the next day it isn't raining...
Old Oct 11, 2018 | 01:19 PM
Old_Duck's Avatar
Old_Duck
Old Oct 11, 2018 | 01:22 PM
Old_Duck's Avatar
Old_Duck
Sarge
Do you have the part number for the cable shown in your photo?
Thanks Duck
Old Oct 11, 2018 | 01:26 PM
dthrckt's Avatar
dthrckt
Awesome, thanks. If that matches the tailgate camera, this should be easy.
Old Oct 12, 2018 | 07:41 AM
dthrckt's Avatar
dthrckt
Got a reply.
"Thanks,
We have engineering discussing now. We will need to bring a vehicle in to validate. Once a decision in made we will contact you hopefully with a solution.
Regards,
Rostra Technical Support"
Old Oct 12, 2018 | 08:23 AM
Section179's Avatar
Section179
Keep us posted...
Old Oct 12, 2018 | 10:35 AM
Sarge261's Avatar
Sarge261
Originally Posted by Old_Duck
Sarge
Thanks Duck
I do not it came with the 3rd brake lamp/camera assembly....here is a thread I started as Im trying to work through adding this camera to my truck.
https://www.ford-trucks.com/forums/1...-camera-6.html
Sarge
Old Nov 6, 2018 | 09:49 AM
Narayan's Avatar
Narayan
Two things:
Since I’m also getting a cap for my soon-to-be-delivered 250, I am also interested in moving the camera into the bed. So if there are any updates to this connector by Rostra, I’d be thrilled.
But out looking at the photos above, wouldn’t a completely viable solution be to snip the wires going to the existing molex connector then use crimped connectors and additional wire to extend the wires to the camera (I’m assuming the camera can be easily detached from the light assembly) wherever you want it in the bed? Presumably you could even feed those wires back into the cab and through to the bed from underneath to avoid drilling a hole in the cap up where the CHSML is.
My my truck should arrive within a week and its ARE Z-series cap by the 15th. I’ve got quite a bit happening in the next few months and would rather not pull the cap off once it is installed so I’m either going to do this in that intervening week or forget about it until next year sometime.
Old Nov 24, 2018 | 02:40 PM
95cobby's Avatar
95cobby
Any updates? Interested in moving the camera as well.
Old Jul 15, 2021 | 10:29 AM
Mr Blotto's Avatar
Mr Blotto
Has anyone figured this out / have an update on this? I too am looking to relocate my CHMSL & camera from the stock location to the back of my upfitter box on my '21 F-350 XLT.
Thanks
Old Jul 15, 2021 | 11:25 AM
dthrckt's Avatar
dthrckt
I emailed the company several more times. I even found the CEO email and emailed that address, then I finally got a response from someone (not CEO). They didn't respond again. I guess they don't want our money.
I'm sure there's a way to do this, but I've not taken the time. When I get a bigger boat then I will because it will certainly be worth it.
Old Jul 15, 2021 | 11:47 PM
Ding126's Avatar
Ding126
Has anyone contacted Lawrence @ Boostedgraygoose? He may have a solution or make one
Old Jul 17, 2021 | 07:29 PM
  #28
34SF's Avatar
34SF
I disconnected my CHMSL for my Leer cap. There were no negative effects with not having a camera. I could never find a plug that worked for this and tried making one from a defective camera but the contacts are very small. I tried everywhere, just trying to find a plug that fit and nothing. Finally just used the 3M taps.
I had some success with an after-market high quality camera but I did have to tap the wires at the plug. The camera I'm using has a loop for backup lines which I removed and I can select the view I want with the camera selector button. Other projects took over and I haven't finished this yet but eventually I will run a cable under the truck for this so I can spy on my dogs in the back. So...it can be done but without a legit connector. The image quality is the same as the OEM cameras despite being listed as a "high resolution" camera so I think this is more an issue of the monitor screen than the resolution of the lens.
Old Dec 17, 2021 | 05:01 PM
  #29
denisberger's Avatar
denisberger
So you figured out the wires? I am assuming Black is ground, red is power (12V), but what are green blue and white? i was expecting just 2 more wires for vid+ and vid-.
Wannaf250
Jan 31, 2017 08:57 PM
Hummah Zach
2004 - 2008 F150
Apr 23, 2009 08:41 PM
davidandbess
2004 - 2008 F150
Sep 9, 2008 04:15 AM
MikeDaddy
1983 - 2012 Ranger & B-Series
Dec 21, 2005 11:09 PM
gypsyclimber
Aug 19, 2002 08:15 PM
