Distributer problems
Old Feb 8, 2018 | 09:22 PM
Fordfamily11's Avatar
Fordfamily11
I keep blowing rotors in my distributer good thing is their lifetime but i want my truck fixed , i tried doing research and i think its my pickup coil , if it is please tell me i really could use the expert mechanic help , and if it is is it just easier to do the pickup coil or just do a new distributer ? And my other ? Is the oil pump shaft coming off and falling down inside . Thank you ford fellows .
Old Feb 8, 2018 | 09:36 PM
88n94's Avatar
88n94
Explain exactly what happens to the rotors?
Old Feb 8, 2018 | 10:45 PM
mrollings53's Avatar
mrollings53
If your oil pump shaft fell into the oil pan you wouldn't have any oil pressure. This seems rather obvious, but watch the gauge after you start the motor.
Old Feb 12, 2018 | 09:35 AM
Fordfamily11
The metal piece on the rotor that conducts with the cap blows off , my guy at my autozone really hooked me up , he said instead of you coming in for $200 in lifetime warrenty rotors here i will give you this new lifetime distributor . But i think the problem was the pickup coil but no one says anything about rotors going bad .
Old Feb 12, 2018 | 02:10 PM
willowbilly3's Avatar
willowbilly3
I would suspect some very sloppy distributor shaft bushings after the second one.
the kid
Nov 12, 2006 02:13 PM
4x4bigblock
Feb 23, 2006 08:38 AM
GLASSPACK
1997 - 2003 F150
Jun 5, 2005 10:07 PM
mtnman64
Aug 27, 2004 10:49 AM
myer
1978 - 1996 Big Bronco
Aug 25, 2001 09:43 PM
