1978 - 1996 Big Bronco
5.8 eats caps and rotors
Old Aug 22, 2001 | 10:22 PM
myer's Avatar
myer
I have a 1989 5.8L xlt. It eats caps and rotors. I have lately been buying the brass contact caps which seem to last a little longer. Does anyone else have this problem? Any fixes?
Thanks
myer
Old Aug 23, 2001 | 08:40 PM
restorit's Avatar
restorit
Is it possible that your distributor shaft is slightly bent or tweaked towards the upper (rotor) end, or that it has excessive play or wear? Have you considered changing it out for a remanufactured one? Just some thoughts, assuming that your truck is eating the caps and rotors through wear, and not through excessive voltage. If the latter is true, I couldn't tell you. Some sort of coil resistor, perhaps???? There are many more out there who know more about the ignition physics of these than myself. How are your plugs and wires holding up?
Old Aug 23, 2001 | 10:21 PM
myer's Avatar
myer
The caps and rotors get burned, almost look if the metal melts where the rotor passes. The plugs and wires I just changed yesterday, they seemed to have normal wear.
myer
Old Aug 24, 2001 | 09:17 PM
thelonerangerxlt's Avatar
thelonerangerxlt
I think Restorit is on the right track with the ballast resistor, or in your case, a resistor wire. If you have a multimeter, check the voltage on the positive side of the coil, with the engine off and the key on. You should have about 8-9V. If it is over 12V, then you should install a ballast resistor in the wire before the coil to drop the voltage.
I think that a previous owner may have had trouble with the resistor wire, and just ran a common wire to the coil from the switch.
Good luck.
Old Aug 24, 2001 | 09:26 PM
myer's Avatar
myer
I have owned the truck since new, it now has 103700 miles and it has burned up caps all along. Will a new coil solve this problem? Thanks for all you input.
myer
Old Aug 25, 2001 | 09:31 PM
thelonerangerxlt
[font size="1" color="#FF0000"]LAST EDITED ON 25-Aug-01 AT 10:33 PM (EST)[/font][p]Myer, that's a lot of caps and rotors! Yes, it could be the coil. I would check for the proper voltage coming to the pos terminal of the coil (8-9V), and if this is OK, then change the coil. Before you do this, make sure that the ground strap to the engine is clean and tight, and also the battery ground cable to the engine.
Old Aug 25, 2001 | 09:43 PM
79BroncoJD's Avatar
79BroncoJD
Paul Myers
Jun 11, 2017 11:52 AM
FORDF250HDXLT
Mar 26, 2017 04:13 PM
fljab
Mar 10, 2017 12:21 PM
Blaine Myers
Mar 1, 2017 12:49 AM
Upfront
17
Jan 19, 2016 09:31 AM
