What parts will work?
Old Feb 7, 2018 | 09:12 AM
Dano61's Avatar
Dano61
I got a 1985 Ford F-150 as a donor truck and will soon be pulling the 302 out of it and prepping it to go into the ‘66 F100. My question is, will the steering column switch over as well? Does anyone know what other parts from the donor truck will I be able to use? I would also really like to switch rear ends as well.
Thanks in in advance for your expert experiences!
Old Feb 7, 2018 | 02:48 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1980 and later steering columns will not work on any 1979 or older truck.
The rear axle is wider, because in 1973, Ford increased the width of the inner frame rails behind the cab from 33 1/2" used 1957/72 to 37 1/2."
And, 1983 F100's and 1983/86 F150's were available with two different rear axles.
The 9" (1957/86) and the Ford 8.8" integral rear axle introduced in 1983.
Old Feb 7, 2018 | 03:55 PM
Dano61's Avatar
Dano61
Thanks for the info!
Old Feb 9, 2018 | 07:50 PM
Dano61's Avatar
Dano61
ND, your comment about the steering column being from 1980 on, does that mean anything 1979 and older would work?
Old Feb 9, 2018 | 09:00 PM
NumberDummy
People swap the tilt wheel columns from 1978/79's into their 1965/66 F100/250 2WD's, so...
Old Mar 4, 2018 | 09:34 AM
Dano61's Avatar
Dano61
In prepping for the 302, I have a question I’m sure someone here can answer. Is there a set of motor mounts I can buy that will allow me to simply drop the 302 into my ‘66? Or will I have to manufacture some?
Also, while prepping to pull the 240 I’ve noticed that there are multiple hole set positions for the motor mounts to mount to the frame. Are these different hole sets for larger engines? Will any of these work with the 302, or will I have to redrill to mount the motor mounts?
thanks in advance.
Old Mar 4, 2018 | 09:47 AM
NumberDummy
Same R & L engine supports aka towers/stands/perches: 1969/79 F100 302; 1975/79 F150 302; 1977/79 F100/350 2WD 351M/400.
Old Mar 4, 2018 | 09:51 AM
Dano61's Avatar
Dano61
Thanks ND!
Imallearsfor59s
Oct 26, 2018 02:58 PM
ctubutis
May 10, 2011 04:51 PM
SportCustomWalt
Feb 9, 2009 12:05 PM
fordlover2
Aug 16, 2004 09:58 AM
