Has anybody used a 1988 steering column in a 80-86 truck?
Old 05-08-2011, 08:39 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Will a 1988 steering column work in a 1981?
I have a 1981 F350, tilt-wheel, floor-mounted manual transmission.
Will a 1988 column work? I would imagine it'd physically line up, correct? But I'm not sure about the electrical.
1981 doesn't have the key-in-ignition buzzer, I can either 1) transfer over my 1981 switch, or 2) use the 1988 switch if it's electrically compatible?
But the 1988 has cruise control.
1988 doesn't have stalk-mounted wiper or headlight controls; the steering wheel is different but they way it mounts is the same.
Does anybody know if this will work?
Old 05-09-2011, 07:32 AM
Archion's Avatar
Archion
Archion is offline
Im pretty sure they are the same internally, at least with my 86. I have one for a 90 that I am going to see about putting in this weekend when I do my steering box and pump. As for the buzzer, I'm not sure. I know the turn signal switch is the same as my 86, and I can put my 86 wheel on it no problem. I just looked up the switch, and it was changed in 85 and ran all the way through 90. Your switch was only used from 80-83 according to the catalog. Maybe if you swap the wiring stuff over it would work?
Old 05-09-2011, 01:57 PM
glovemeister's Avatar
glovemeister
glovemeister is offline
Ct, is it keeping it original that makes you interested in the seatbelt buzzer warning setup? If not just leave that off.
Old 05-09-2011, 03:25 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
81-F-150-Explorer is offline
The 1980-1983 tilt column turn signal switch will bolt up to the later 1984-1986 tilt columns.
I was not sure if the columns themselves were physically different or not at the steering wheel. If the column will except the tilt turn signal switch from an 1986, and a 1986 steering wheel will bolt on, the 1981 tilt turn signal switch and parts will work with it too.
What's got me concerned is the tilt column differences.
I already know this swap is possible with standard columns.
Old 05-09-2011, 09:39 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
I'm mostly wondering if my switch (which I bought brand new from the $dealer a few years ago) can be attached to the 1988 column or if the 88 switch will plug into my harness.
Old 05-10-2011, 11:00 AM
BikeMaker's Avatar
BikeMaker
BikeMaker is offline
I put a tilt column out of a 89 in my 84. Both had tilt, 89 was out of a manual truck (same place my engine/trans came from), and the 84 was an auto setup to match the stock C6 trans.
Everything bolted right up; horn, turn signals, flashers, ignition switch worked just fine. Haven't tried the cruise control yet.
Old 05-10-2011, 12:00 PM
81-F-150-Explorer
Thanks for this info! good to know.
Old 05-10-2011, 04:51 PM
IDIDieselJohn's Avatar
IDIDieselJohn
IDIDieselJohn is offline
And if you like better the old steering, ( I do anyways ) there a direct swap in!
Jacob-M
22
04-25-2017 08:45 PM
wrd0225
08-23-2016 04:17 PM
Pearl Jack
09-21-2015 02:35 AM
RotGrubestier44
13
11-20-2012 09:45 AM
rhoward
10-05-2009 11:08 AM
Quick Reply: Has anybody used a 1988 steering column in a 80-86 truck?
