Anyone know what this goes to? Wiring issue
Idk why this is upside down.....
hey all, I need to see if anyone knows what this goes to. Im having a charging issue even after replacing both the battery and the alternator (came with new voltage regulator).
Edit: the wire is light green with a red stripe. The end that isn’t cut runs to the positive battery wire, and into the alternator. Or its at least lumped in with those.
So if I understand this correctly, this is not providing the alternator what it needs to work correctly? So that would cause the alternator to not charge the battery?
Also, would you happen to know what category this might be under in like rockauto for a replacement? And as to where the wire is supposed to connect?
This is for a 1994 F series/Bronco, should be the same for your 1993
Charge indicator is a lamp in the instrument cluster.
One of the photos you posted shows that Light Green/Red wire coming out of the wiring loom and one side of the connector (C139 female). The male end should have the same Light Green/Red wire that connects to the alternator (via connector C154).
Assuming your truck has a 2G alternator the connector is here (upper circled item):
Take a small flat head screwdriver (jeweler's/eyeglasses) & work the silicon plug out of the end.
Pull the red locking wedge out of the barrel.
Use a sharp pick to ease the retaining tab back that holds the pin while pulling the stub of wire.
Not too far or it'll break.
Splice, solder, heat shrink re-assemble.
Turn key to on, no start & see if the bulb illuminates.
sere0501
04-21-2018 05:17 PM
NW 150
05-07-2015 08:25 PM
SleeprLegend
15
05-06-2010 10:28 PM
