Distributor pin breaking
Old Feb 4, 2018 | 10:06 PM
ap123363's Avatar
ap123363
4wd Low
Hi I have had the pin the holds the distributor gear break three times now on heavy load or high RPMs on my '85 300-6. Is this something fairly common?
Is there a high performance distributor that you would recommend over stock?
Any thoughts are appreciated as getting stranded is getting old.
Thanks! -Al
Old Feb 4, 2018 | 10:20 PM
The Frenchtown Flyer's Avatar
Fairly common
Replace it w/ a piece of 1/8 steel welding rod with a ball melted on each end by a TIG torch.
Problem solved for good.
The original roll pins are too brittle.
Old Feb 5, 2018 | 09:56 AM
AbandonedBronco's Avatar
AbandonedBronco
I've had several break on me too. Very annoying and has left me stranded a few times.
Just be sure it isn't another issue, like an old oil pump not spinning freely.
Old Feb 6, 2018 | 10:08 AM
ap123363's Avatar
ap123363
4wd Low
Originally Posted by The Frenchtown Flyer
Fairly common
Thanks to you both, great advice!-Al
blisstruck
Jan 19, 2017 09:57 AM
jgan
May 5, 2009 11:05 AM
jheroux
Apr 8, 2005 10:25 PM
heavensrockin
Jul 29, 2002 02:11 PM
Ed Norton
May 26, 2002 06:38 PM
